Unfortunately I didn't find the USB Control plugin in the plugin manager, so I installed it manually. (current version 1.0.7) .
then I restarted octoprint and after that the plugin was disabled every time...
then I tried to reinstall it again but unfortunately always the same error...
see also unfortunately no settings as it is in the instructions.
have the current version of octoprint installed on a raspi 3B please help.
here the info:browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36
connectivity.connection_check: 1.1.1.1:53
connectivity.connection_ok: true
connectivity.enabled: true
connectivity.online: true
connectivity.resolution_ok: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 915058688
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.18.0
env.plugins.pi_support.throttle_state: 0x50000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
2021-03-30 22:52:53,437 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
Okay,that can be..my power supply has a capacity of 2 A..I thought that it is enough for the Raspi, because only octoprint runs on it. but I will change and use a stronger one.thanks
okay, about the plugin.
is there a solution besides update ? is there another way to disable the usb ports ?
or rather another raspi ?
okay, so this is the plugin that turns off the power ?
the problem is that when i turn off the power from the 3d printer, the board still gets minimal power from the raspi.
so the lcd display was on and the fans got so much power that they started to beep.
