Hey y'all, beginner here. I've been using my Octopi just fine, but for some reason the octopi UI keeps on saying the connection is refused. I can ssh into it with putty just fine, but trying the IP address from the terminal and the octopi.local keeps on showing me the same issue. I assume getting a new install of the os is gonna fix everything and just start from a clean plate, but I'm pretty confident this is gonna get me again as soon as I try using multiple instances on it.
Tried the IP address, rebooted with ssh, and rewrote the SSID just in case if it was on a different network
N/A(unless there's a way to do that in the terminal)
N/A
(mb i have no clue how to do this using only ssh)
A raspberry pi 4 model B with 8 GB of RAM
using a PI cam V1
running octoprint version 1.10.3, and octopi version 1.0.0
