I installed Octoprint to use on my Ender 3 V2, but it wont connect to my printer. It keeps giving errors saying Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)or State: Offline (Error: Could not write to serial port). And if it does connect it'll connect for a minute then disconnect.
I've set the connection settings to auto, I've tried new cables.
Yes
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xaad2dc50, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Performing autodetection with 4 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyAMA0@115200, /dev/ttyAMA0@250000
Trying port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xaabbdff0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Handshake attempt #2 with timeout 2.0s
Send: N0 M110 N0125
Handshake attempt #3 with timeout 2.0s
Send: N0 M110 N0*125
I am using the latest version of Octoprint 1.5.3. I am running it on my Raspberry Pi 4.
