Problem addressing multiple webcams with new camera stack (only port 8080 streaming)
Camera model LocitecC270 and 2x no-name cameras (all worked separately in the past)
I followed the instructions here: https://community.octoprint.org/t/camera-streamer-configuration-on-the-new-camera-stack-for-octopi/49950
I had all 3 cameras registered with sudo add-usb-camera <name>, each with a unique name and port 8080,8081,8082
As predicted only one on port 8080 is streaming:
That is all great and went smoothly, but how do I access the other cameras???
I must be missing something super simple...
http:"< ID >":8080/stream --> works fine
http:"< ID >":8081/stream --> "Server error"
OctoPrint 1.9.0
OctoPi 1.0.0
Please share a systeminfo bundle, that contains the logs. It will say what the server error is.
octoprint-systeminfo-20230602075616.zip (45.4 KB)
This is the systeminfo bundle. I hope this contains information to pinpoint the problem.
Thanks for your help!
Best regards
Stephan
Meanwhile, I reverted back to the webcamd version of Octopi and Octoprint (0.18.0 and 1.9.0). I was able to get all three cameras working with the article Setting up multiple webcams.
Still, I was wondering what I missed using the new camera stack version...
Again, thanks for helping.
Stephan
in the new stack it's a matter of adding additional configurations. check out the Configuring multiple cameras section over here on the FAQ.
I did follow these instructions and have configured all three cameras without problems. But I seem to be able to only see the one on port 8080. How can I access the other cameras (the configuration files are there, showing ports 8081 and 8082).
Sorry for missing replying to this one - can you make sure that you have updated the 'Pi Support' plugin, so that the system info bundle can capture the log files of the new camera stack as well? It should be version 2023.5.24.
After that is updated, with your multiple cameras setup, connected and configured as you want, share a new systeminfo bundle and hopefully the logs may shed some light on what is broken.
Hello Charlie. Thanks so much for your support. I have updated all the plugins, including the Pi Support plugin and created a new systeminfo bundle. It is attached to this message.
As before, all three cameras seem to be configured with their .conf files present in /boot/camera-streamer. Hope this helps to find a solution...
Best regards
Stephan
octoprint-systeminfo-20230605223156.zip (24.4 KB)
All three cameras are recognised by the system, so that's a good start.
Your 'oldCam' camera doesn't seem to support the YUVY capture mode, only providing JPEG mode. In the config file for that one, try switching FORMAT=YUVY to show FORMAT=JPEG.
Is it the C270 that is working?
I can't see anything obvious for the 'chinaCam' that is an error. Earlier today, I had an issue with my setup where it showed 'server error' when I booted my Pi on my second camera, with no obvious error in the logs. Running sudo camera-streamer-control restart fixed that one and both my cameras were back working again, so give that a try.
So, I changed the oldCam to JPEG. Nothing changed, however :confused:
You are correct, the logitech is the camera that works on port 8080. If I try the camera on 8081 (chinaCam) I get "Server Error", and if I try the camera on 8082 (oldCam) I get "Error: Connection failed". That is somehow strange...
I also tried to restart camera-streamer-control like you suggested. No change. Is there anything I can do (or provide any log) to get to the bottom of this?? Again, thank you so much for your effort.
Stephan
Just working through this myself, I needed to change the FORMAT to MJPEG in my case for my random brand of USB cam, had the same server error.
The other thing I changed the the resolution to one I knew the camera supported.
I have editied my haproxy.cfg to try and get the other camera visible under webcam2,
Good to know, that I am not alone in this.
I will try the MJPEG, but I am on vacation right now and I won't have an opportunity to investigate this further until next weekend...
