i have a cr-10s that prints perfectly with no issues. i then got a raspberry pi 4b with 1gb, installed octoprint using my windows machine and it seemed to install fine. i can get to the pi using browser and it responds ok and allows me to install plug-ins and other octoprint support tasks. i then plugged the cable into to cr-10s serial port and turned on the printer. i hit the connect button and octoprint recognized that i have a dangerous firmware and indicates that the connection is stable.
However, there is no live connection and everytime i try to send anything to the printer, a gcode command or a print file, i get a series of "communication timeout while idle" messages in response.
have tried using different cables and turning printer on with/without sd card inserted and problem continues
did try in safe mode and the connection seems stable
was able to get my first print thru octoprint! do i have a conflict with my plug-ins?
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36 Edg/90.0.818.49
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 842829824
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.throttle_state: 0x50000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.6.0
printer.firmware: Marlin 1.1.0 From Archive
