Problem with Alfawise U30 Pro (LCD Loading) (solved)
Hello everywhere
In reallity, I have 2 problems:
  • First, When I plug USB cable to my Printer, and put switch on, the LCD screen display Loading, and restart loading a lot of time. When I acheive to start printer normally, I can control it with octopi, and start print.
    I have an icon not blinking undervoltage, but I use a 2A power charger.
  • Second one is: when the printer is power off, I see on LCD a blinking loading icon. Need to unplug USB cable to disappear this icon
Last one, but I didn't check try solve by topic (really long to send gcode to sd)
By playing with usb cable, and connect button
Problem not seems to be on octprint !?
Octoprint version: Latest
Printer: Alfawise U30 Pro
Firmware: Marlin1.1.9 LGT 0.3.1
For info, I use a RPi 2 without camera (don't have it)
The third problem I speak is:
I want to send a 3Mo file to SD with octopi. Time remain: Sending file to SD 17 min remain, 08 min elapsed :confused:
Second one should also be solved by this.
To your third problem:
Yeah it's a slow serial connction and transmitting data takes its time :wink:
But you know you don't have to send it to your printers sd card, right? Just load the gcode into octoprint and print it :slight_smile:
Hello, I tried type on 5V but now, unable to connect to printer :confused:
Edit: Arf wrong pin
It's ok now for 1st and 2th, thanks
For the third, it's to keep autonomous printer, to don't need to open computer to print some parts :slight_smile:
