RaspberryCam crashes after printing start
RasperyPi Cam
Hi, the camera itself works great, but when I start printing, the camera seems to crash.
When I move the Z-Axis, it still works, but as soon as i start moving the X or Y-Axis in the control-tab, the picture freezes and i cannot bring it back to work. Only possibility is to restart the system. It all worked until I updated to 1.4.1 and the day after to 1.4.2.
does anybody have a tipp, what I should look for ?
tried to check the logs, but I have no clue what to look for.
edit 15:08 07.08.2020: Looked through other threads: tried with Safemode, same result.
restarting the service worked only once, when x-y-Movement is triggered it crashes again and then the restart of the service does not work.
I checked the configuration via ssh, everything fine.
Accessing the Camera with direct URL, does not work.
the only information I could find in logs is this after moving the x-Axis:
Aug 7 11:53:27 octopi kernel: [ 12.793265] Bluetooth: BNEP socket layer initialized
Aug 7 12:03:53 octopi MJPG-streamer [419]: select() timeout
Aug 7 12:03:53 octopi MJPG-streamer [419]: cleaning up resources allocated by input thread
syslog:
Aug 7 12:03:53 octopi webcamd[324]: i: select() timeout
Aug 7 12:03:53 octopi webcamd[324]: i: cleaning up resources allocated by input thread
webcamd.log is not /var/log to find.
OctoPrint Version 1.4.2 OctoPi 0.17, PiCam attached with ribbon cable, browser: Chrome, IE, FF, Safari
I startet the Webcam daemon manually and startet a new print, and there are some details from syslog, what happened when the X-Y-Movement started:
Aug 7 21:23:08 octopi webcamd[3580]: i: select() timeout
Aug 7 21:23:08 octopi webcamd[3580]: i: cleaning up resources allocated by input thread
Aug 7 21:23:08 octopi MJPG-streamer [3593]: select() timeout
Aug 7 21:23:08 octopi MJPG-streamer [3593]: cleaning up resources allocated by input thread
Aug 7 21:23:11 octopi kernel: [15037.258626] bcm2835_mmal_vchiq: timed out waiting for sync completion
Aug 7 21:23:11 octopi kernel: [15037.258649] bcm2835-v4l2: port_disable failed, error -62
Aug 7 21:23:12 octopi kernel: [15038.298698] bcm2835-v4l2: stop_streaming: Timeout waiting for buffers to be returned - 4 outstanding
Aug 7 21:23:15 octopi kernel: [15041.338650] bcm2835_mmal_vchiq: timed out waiting for sync completion
Aug 7 21:23:15 octopi kernel: [15041.338682] bcm2835-v4l2: Failed disabling camera, ret -62
Aug 7 21:23:15 octopi kernel: [15041.338692] bcm2835-v4l2: Failed to disable camera
Aug 7 21:23:15 octopi kernel: [15041.338702] ------------[ cut here ]------------
Aug 7 21:23:15 octopi kernel: [15041.338757] WARNING: CPU: 0 PID: 3595 at drivers/media/common/videobuf2/videobuf2-core.c:1688 __vb2_queue_cancel+0x158/0x1c8 [videobuf2_common]
Aug 7 21:23:15 octopi kernel: [15041.338773] Modules linked in: nft_counter nft_chain_route_ipv4 xt_DSCP xt_tcpudp nft_compat nf_tables nfnetlink bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc ch341 usbserial brcmfmac brcmutil vc4 sha256_generic drm_kms_helper v3d gpu_sched cfg80211 snd_soc_core snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops drm rfkill drm_panel_orientation_quirks raspberrypi_hwmon bcm2835_v4l2(C) hwmon snd_bcm2835(C) bcm2835_codec(C) v4l2_common v4l2_mem2mem bcm2835_mmal_vchiq(C) snd_pcm videobuf2_vmalloc videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 snd_timer videobuf2_common snd videodev vc_sm_cma(C) media rpivid_mem uio_pdrv_genirq fixed uio ip_tables x_tables ipv6
Aug 7 21:23:15 octopi kernel: [15041.339363] CPU: 0 PID: 3595 Comm: mjpg_streamer Tainted: G C 4.19.75-v7l+ #1270
Aug 7 21:23:15 octopi kernel: [15041.339371] Hardware name: BCM2835
Aug 7 21:23:15 octopi kernel: [15041.339405] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
Aug 7 21:23:15 octopi kernel: [15041.339424] [] (show_stack) from [] (dump_stack+0xd4/0x118)
Aug 7 21:23:15 octopi kernel: [15041.339442] [] (dump_stack) from [] (__warn+0x104/0x11c)
Aug 7 21:23:15 octopi kernel: [15041.339458] [] (__warn) from [] (warn_slowpath_null+0x50/0x58)
Aug 7 21:23:15 octopi kernel: [15041.339491] [] (warn_slowpath_null) from [] (__vb2_queue_cancel+0x158/0x1c8 [videobuf2_common])
Aug 7 21:23:15 octopi kernel: [15041.339547] [] (__vb2_queue_cancel [videobuf2_common]) from [] (vb2_core_streamoff+0x44/0xb4 [videobuf2_common])
Aug 7 21:23:15 octopi kernel: [15041.339589] [] (vb2_core_streamoff [videobuf2_common]) from [] (vb2_streamoff+0x40/0x60 [videobuf2_v4l2])
Aug 7 21:23:15 octopi kernel: [15041.339625] [] (vb2_streamoff [videobuf2_v4l2]) from [] (vb2_ioctl_streamoff+0x50/0x684 [videobuf2_v4l2])
Aug 7 21:23:15 octopi kernel: [15041.339710] [] (vb2_ioctl_streamoff [videobuf2_v4l2]) from [] (v4l_streamoff+0x28/0x2c [videodev])
Aug 7 21:23:15 octopi kernel: [15041.339845] [] (v4l_streamoff [videodev]) from [] (__video_do_ioctl+0x268/0x528 [videodev])
Aug 7 21:23:15 octopi kernel: [15041.339972] [] (__video_do_ioctl [videodev]) from [] (video_usercopy+0x218/0x600 [videodev])
Aug 7 21:23:15 octopi kernel: [15041.340097] [] (video_usercopy [videodev]) from [] (video_ioctl2+0x20/0x24 [videodev])
Aug 7 21:23:15 octopi kernel: [15041.340222] [] (video_ioctl2 [videodev]) from [] (v4l2_ioctl+0x4c/0x60 [videodev])
Aug 7 21:23:15 octopi kernel: [15041.340296] [] (v4l2_ioctl [videodev]) from [] (do_vfs_ioctl+0xbc/0x804)
Aug 7 21:23:15 octopi kernel: [15041.340317] [] (do_vfs_ioctl) from [] (ksys_ioctl+0x44/0x6c)
Aug 7 21:23:15 octopi kernel: [15041.340335] [] (ksys_ioctl) from [] (sys_ioctl+0x18/0x1c)
Aug 7 21:23:15 octopi kernel: [15041.340352] [] (sys_ioctl) from [] (ret_fast_syscall+0x0/0x28)
Aug 7 21:23:15 octopi kernel: [15041.340361] Exception stack(0xda8affa8 to 0xda8afff0)
Aug 7 21:23:15 octopi kernel: [15041.340373] ffa0: 86c1fa00 00000000 00000004 40045613 b6918f48 00000001
Aug 7 21:23:15 octopi kernel: [15041.340386] ffc0: 86c1fa00 00000000 40045613 00000036 00000001 b6da3004 00000004 b691b930
Aug 7 21:23:15 octopi kernel: [15041.340395] ffe0: b6918f48 b6918f38 b6d8c958 b6e95af0
Aug 7 21:23:15 octopi kernel: [15041.340405] ---[ end trace 30043498885cf93c ]---
Aug 7 21:23:15 octopi kernel: [15041.340419] videobuf2_common: driver bug: stop_streaming operation is leaving buf feff8581 in active state
Aug 7 21:23:15 octopi kernel: [15041.340432] videobuf2_common: driver bug: stop_streaming operation is leaving buf e8a70342 in active state
Aug 7 21:23:15 octopi kernel: [15041.340445] videobuf2_common: driver bug: stop_streaming operation is leaving buf 68628c4e in active state
Aug 7 21:23:15 octopi kernel: [15041.340457] videobuf2_common: driver bug: stop_streaming operation is leaving buf e738c2fe in active state
Aug 7 21:25:17 octopi systemd[1]: Stopping the OctoPi webcam daemon with the user specified config...
Aug 7 21:25:17 octopi systemd[1]: webcamd.service: Main process exited, code=killed, status=15/TERM
Aug 7 21:25:17 octopi systemd[1]: webcamd.service: Succeeded.
Aug 7 21:25:17 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Aug 7 21:25:17 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Aug 7 21:25:17 octopi webcamd[3651]: Starting up webcamDaemon...
Aug 7 21:25:17 octopi webcamd[3651]: --- Configuration: ----------------------------
Aug 7 21:25:17 octopi webcamd[3651]: cfg_file: /boot/octopi.txt
Aug 7 21:25:17 octopi webcamd[3651]: camera: auto
Aug 7 21:25:17 octopi webcamd[3651]: usb options: -r 640x480 -f 10
Aug 7 21:25:17 octopi webcamd[3651]: raspi options: -fps 10
Aug 7 21:25:17 octopi webcamd[3651]: http options: -w ./www-octopi -n
Aug 7 21:25:17 octopi webcamd[3651]: Explicitly USB device:
Aug 7 21:25:17 octopi webcamd[3651]: -----------------------------------------------
Aug 7 21:26:29 octopi kernel: [15235.180473] INFO: task kworker/3:1:40 blocked for more than 120 seconds.
Aug 7 21:26:29 octopi kernel: [15235.180487] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:26:29 octopi kernel: [15235.180497] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:26:29 octopi kernel: [15235.180508] kworker/3:1 D 0 40 2 0x00000000
Aug 7 21:26:29 octopi kernel: [15235.180551] Workqueue: events dbs_work_handler
Aug 7 21:26:29 octopi kernel: [15235.180589] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:26:29 octopi kernel: [15235.180609] [] (schedule) from [] (schedule_preempt_disabled+0x18/0x1c)
Aug 7 21:26:29 octopi kernel: [15235.180631] [] (schedule_preempt_disabled) from [] (__mutex_lock.constprop.5+0x1a8/0x590)
Aug 7 21:26:29 octopi kernel: [15235.180650] [] (__mutex_lock.constprop.5) from [] (__mutex_lock_slowpath+0x1c/0x20)
Aug 7 21:26:29 octopi kernel: [15235.180669] [] (__mutex_lock_slowpath) from [] (mutex_lock+0x5c/0x60)
Aug 7 21:26:29 octopi kernel: [15235.180690] [] (mutex_lock) from [] (rpi_firmware_transaction+0x54/0xd0)
Aug 7 21:26:29 octopi kernel: [15235.180709] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:26:29 octopi kernel: [15235.180726] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:26:29 octopi kernel: [15235.180745] [] (rpi_firmware_property) from [] (bcm2835_cpufreq_clock_property.constprop.1+0x58/0x80)
Aug 7 21:26:29 octopi kernel: [15235.180766] [] (bcm2835_cpufreq_clock_property.constprop.1) from [] (bcm2835_cpufreq_driver_target_index+0x5c/0xe4)
Aug 7 21:26:29 octopi kernel: [15235.180785] [] (bcm2835_cpufreq_driver_target_index) from [] (__cpufreq_driver_target+0x2d8/0x5a8)
Aug 7 21:26:29 octopi kernel: [15235.180803] [] (__cpufreq_driver_target) from [] (od_dbs_update+0xa8/0x174)
Aug 7 21:26:29 octopi kernel: [15235.180821] [] (od_dbs_update) from [] (dbs_work_handler+0x3c/0x68)
Aug 7 21:26:29 octopi kernel: [15235.180843] [] (dbs_work_handler) from [] (process_one_work+0x170/0x458)
Aug 7 21:26:29 octopi kernel: [15235.180861] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:26:29 octopi kernel: [15235.180877] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:26:29 octopi kernel: [15235.180894] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:26:29 octopi kernel: [15235.180906] Exception stack(0xefaabfb0 to 0xefaabff8)
Aug 7 21:26:29 octopi kernel: [15235.180918] bfa0: 00000000 00000000 00000000 00000000
Aug 7 21:26:29 octopi kernel: [15235.180932] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:26:29 octopi kernel: [15235.180944] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:26:29 octopi kernel: [15235.180990] INFO: task kworker/1:1:3636 blocked for more than 120 seconds.
Aug 7 21:26:29 octopi kernel: [15235.181001] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:26:29 octopi kernel: [15235.181010] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:26:29 octopi kernel: [15235.181019] kworker/1:1 D 0 3636 2 0x00000000
Aug 7 21:26:29 octopi kernel: [15235.181055] Workqueue: events get_values_poll [raspberrypi_hwmon]
Aug 7 21:26:29 octopi kernel: [15235.181084] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:26:29 octopi kernel: [15235.181103] [] (schedule) from [] (schedule_timeout+0x200/0x428)
Aug 7 21:26:29 octopi kernel: [15235.181122] [] (schedule_timeout) from [] (wait_for_common+0xd4/0x1b0)
Aug 7 21:26:29 octopi kernel: [15235.181141] [] (wait_for_common) from [] (wait_for_completion+0x20/0x24)
Aug 7 21:26:29 octopi kernel: [15235.181159] [] (wait_for_completion) from [] (rpi_firmware_transaction+0x78/0xd0)
Aug 7 21:26:29 octopi kernel: [15235.181176] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:26:29 octopi kernel: [15235.181193] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:26:29 octopi kernel: [15235.181214] [] (rpi_firmware_property) from [] (get_values_poll+0x4c/0x15c [raspberrypi_hwmon])
Aug 7 21:26:29 octopi kernel: [15235.181249] [] (get_values_poll [raspberrypi_hwmon]) from [] (process_one_work+0x170/0x458)
Aug 7 21:26:29 octopi kernel: [15235.181265] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:26:29 octopi kernel: [15235.181280] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:26:29 octopi kernel: [15235.181295] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:26:29 octopi kernel: [15235.181306] Exception stack(0xef947fb0 to 0xef947ff8)
Aug 7 21:26:29 octopi kernel: [15235.181317] 7fa0: 00000000 00000000 00000000 00000000
Aug 7 21:26:29 octopi kernel: [15235.181329] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:26:29 octopi kernel: [15235.181341] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:26:47 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: State 'stop-sigterm' timed out. Killing.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Killing process 3651 (webcamd) with signal SIGKILL.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Killing process 3655 (vcgencmd) with signal SIGKILL.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Control process exited, code=killed, status=9/KILL
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Failed with result 'timeout'.
Aug 7 21:28:17 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
Aug 7 21:28:17 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Aug 7 21:28:17 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Aug 7 21:28:18 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Aug 7 21:28:18 octopi webcamd[3680]: Starting up webcamDaemon...
Aug 7 21:28:18 octopi webcamd[3680]: --- Configuration: ----------------------------
Aug 7 21:28:18 octopi webcamd[3680]: cfg_file: /boot/octopi.txt
Aug 7 21:28:18 octopi webcamd[3680]: camera: auto
Aug 7 21:28:18 octopi webcamd[3680]: usb options: -r 640x480 -f 10
Aug 7 21:28:18 octopi webcamd[3680]: raspi options: -fps 10
Aug 7 21:28:18 octopi webcamd[3680]: http options: -w ./www-octopi -n
Aug 7 21:28:18 octopi webcamd[3680]: Explicitly USB device:
Aug 7 21:28:18 octopi webcamd[3680]: -----------------------------------------------
Aug 7 21:28:32 octopi kernel: [15358.061752] INFO: task kworker/3:1:40 blocked for more than 120 seconds.
Aug 7 21:28:32 octopi kernel: [15358.061765] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:28:32 octopi kernel: [15358.061775] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:28:32 octopi kernel: [15358.061786] kworker/3:1 D 0 40 2 0x00000000
Aug 7 21:28:32 octopi kernel: [15358.061829] Workqueue: events dbs_work_handler
Aug 7 21:28:32 octopi kernel: [15358.061868] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:28:32 octopi kernel: [15358.061888] [] (schedule) from [] (schedule_preempt_disabled+0x18/0x1c)
Aug 7 21:28:32 octopi kernel: [15358.061910] [] (schedule_preempt_disabled) from [] (__mutex_lock.constprop.5+0x1a8/0x590)
Aug 7 21:28:32 octopi kernel: [15358.061930] [] (__mutex_lock.constprop.5) from [] (__mutex_lock_slowpath+0x1c/0x20)
Aug 7 21:28:32 octopi kernel: [15358.061949] [] (__mutex_lock_slowpath) from [] (mutex_lock+0x5c/0x60)
Aug 7 21:28:32 octopi kernel: [15358.061969] [] (mutex_lock) from [] (rpi_firmware_transaction+0x54/0xd0)
Aug 7 21:28:32 octopi kernel: [15358.061988] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:28:32 octopi kernel: [15358.062004] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:28:32 octopi kernel: [15358.062024] [] (rpi_firmware_property) from [] (bcm2835_cpufreq_clock_property.constprop.1+0x58/0x80)
Aug 7 21:28:32 octopi kernel: [15358.062046] [] (bcm2835_cpufreq_clock_property.constprop.1) from [] (bcm2835_cpufreq_driver_target_index+0x5c/0xe4)
Aug 7 21:28:32 octopi kernel: [15358.062065] [] (bcm2835_cpufreq_driver_target_index) from [] (__cpufreq_driver_target+0x2d8/0x5a8)
Aug 7 21:28:32 octopi kernel: [15358.062083] [] (__cpufreq_driver_target) from [] (od_dbs_update+0xa8/0x174)
Aug 7 21:28:32 octopi kernel: [15358.062102] [] (od_dbs_update) from [] (dbs_work_handler+0x3c/0x68)
Aug 7 21:28:32 octopi kernel: [15358.062122] [] (dbs_work_handler) from [] (process_one_work+0x170/0x458)
Aug 7 21:28:32 octopi kernel: [15358.062141] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:28:32 octopi kernel: [15358.062157] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:28:32 octopi kernel: [15358.062173] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:28:32 octopi kernel: [15358.062184] Exception stack(0xefaabfb0 to 0xefaabff8)
Aug 7 21:28:32 octopi kernel: [15358.062197] bfa0: 00000000 00000000 00000000 00000000
Aug 7 21:28:32 octopi kernel: [15358.062210] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:28:32 octopi kernel: [15358.062222] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:28:32 octopi kernel: [15358.062269] INFO: task kworker/1:1:3636 blocked for more than 120 seconds.
Aug 7 21:28:32 octopi kernel: [15358.062279] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:28:32 octopi kernel: [15358.062288] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:28:32 octopi kernel: [15358.062297] kworker/1:1 D 0 3636 2 0x00000000
Aug 7 21:28:32 octopi kernel: [15358.062334] Workqueue: events get_values_poll [raspberrypi_hwmon]
Aug 7 21:28:32 octopi kernel: [15358.062363] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:28:32 octopi kernel: [15358.062382] [] (schedule) from [] (schedule_timeout+0x200/0x428)
Aug 7 21:28:32 octopi kernel: [15358.062401] [] (schedule_timeout) from [] (wait_for_common+0xd4/0x1b0)
Aug 7 21:28:32 octopi kernel: [15358.062420] [] (wait_for_common) from [] (wait_for_completion+0x20/0x24)
Aug 7 21:28:32 octopi kernel: [15358.062439] [] (wait_for_completion) from [] (rpi_firmware_transaction+0x78/0xd0)
Aug 7 21:28:32 octopi kernel: [15358.062456] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:28:32 octopi kernel: [15358.062472] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:28:32 octopi kernel: [15358.062493] [] (rpi_firmware_property) from [] (get_values_poll+0x4c/0x15c [raspberrypi_hwmon])
Aug 7 21:28:32 octopi kernel: [15358.062516] [] (get_values_poll [raspberrypi_hwmon]) from [] (process_one_work+0x170/0x458)
Aug 7 21:28:32 octopi kernel: [15358.062533] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:28:32 octopi kernel: [15358.062548] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:28:32 octopi kernel: [15358.062563] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:28:32 octopi kernel: [15358.062573] Exception stack(0xef947fb0 to 0xef947ff8)
Aug 7 21:28:32 octopi kernel: [15358.062585] 7fa0: 00000000 00000000 00000000 00000000
Aug 7 21:28:32 octopi kernel: [15358.062598] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:28:32 octopi kernel: [15358.062610] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:29:48 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Aug 7 21:30:34 octopi kernel: [15480.942838] INFO: task kworker/3:1:40 blocked for more than 120 seconds.
Aug 7 21:30:34 octopi kernel: [15480.942852] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:30:34 octopi kernel: [15480.942862] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:30:34 octopi kernel: [15480.942873] kworker/3:1 D 0 40 2 0x00000000
Aug 7 21:30:34 octopi kernel: [15480.942916] Workqueue: events dbs_work_handler
Aug 7 21:30:34 octopi kernel: [15480.942954] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:30:34 octopi kernel: [15480.942974] [] (schedule) from [] (schedule_preempt_disabled+0x18/0x1c)
Aug 7 21:30:34 octopi kernel: [15480.942995] [] (schedule_preempt_disabled) from [] (__mutex_lock.constprop.5+0x1a8/0x590)
Aug 7 21:30:34 octopi kernel: [15480.943016] [] (__mutex_lock.constprop.5) from [] (__mutex_lock_slowpath+0x1c/0x20)
Aug 7 21:30:34 octopi kernel: [15480.943035] [] (__mutex_lock_slowpath) from [] (mutex_lock+0x5c/0x60)
Aug 7 21:30:34 octopi kernel: [15480.943056] [] (mutex_lock) from [] (rpi_firmware_transaction+0x54/0xd0)
Aug 7 21:30:34 octopi kernel: [15480.943075] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:30:34 octopi kernel: [15480.943092] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:30:34 octopi kernel: [15480.943111] [] (rpi_firmware_property) from [] (bcm2835_cpufreq_clock_property.constprop.1+0x58/0x80)
Aug 7 21:30:34 octopi kernel: [15480.943132] [] (bcm2835_cpufreq_clock_property.constprop.1) from [] (bcm2835_cpufreq_driver_target_index+0x5c/0xe4)
Aug 7 21:30:34 octopi kernel: [15480.943151] [] (bcm2835_cpufreq_driver_target_index) from [] (__cpufreq_driver_target+0x2d8/0x5a8)
Aug 7 21:30:34 octopi kernel: [15480.943169] [] (__cpufreq_driver_target) from [] (od_dbs_update+0xa8/0x174)
Aug 7 21:30:34 octopi kernel: [15480.943188] [] (od_dbs_update) from [] (dbs_work_handler+0x3c/0x68)
Aug 7 21:30:34 octopi kernel: [15480.943209] [] (dbs_work_handler) from [] (process_one_work+0x170/0x458)
Aug 7 21:30:34 octopi kernel: [15480.943227] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:30:34 octopi kernel: [15480.943243] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:30:34 octopi kernel: [15480.943259] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:30:34 octopi kernel: [15480.943270] Exception stack(0xefaabfb0 to 0xefaabff8)
Aug 7 21:30:34 octopi kernel: [15480.943283] bfa0: 00000000 00000000 00000000 00000000
Aug 7 21:30:34 octopi kernel: [15480.943296] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:30:34 octopi kernel: [15480.943308] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:30:34 octopi kernel: [15480.943354] INFO: task kworker/1:1:3636 blocked for more than 120 seconds.
Aug 7 21:30:34 octopi kernel: [15480.943365] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:30:34 octopi kernel: [15480.943374] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:30:34 octopi kernel: [15480.943383] kworker/1:1 D 0 3636 2 0x00000000
Aug 7 21:30:34 octopi kernel: [15480.943419] Workqueue: events get_values_poll [raspberrypi_hwmon]
Aug 7 21:30:34 octopi kernel: [15480.943448] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:30:34 octopi kernel: [15480.943466] [] (schedule) from [] (schedule_timeout+0x200/0x428)
Aug 7 21:30:34 octopi kernel: [15480.943485] [] (schedule_timeout) from [] (wait_for_common+0xd4/0x1b0)
Aug 7 21:30:34 octopi kernel: [15480.943505] [] (wait_for_common) from [] (wait_for_completion+0x20/0x24)
Aug 7 21:30:34 octopi kernel: [15480.943523] [] (wait_for_completion) from [] (rpi_firmware_transaction+0x78/0xd0)
Aug 7 21:30:34 octopi kernel: [15480.943540] [] (rpi_firmware_transaction) from [] (rpi_firmware_property_list+0x140/0x2b0)
Aug 7 21:30:34 octopi kernel: [15480.943556] [] (rpi_firmware_property_list) from [] (rpi_firmware_property+0x7c/0xfc)
Aug 7 21:30:34 octopi kernel: [15480.943576] [] (rpi_firmware_property) from [] (get_values_poll+0x4c/0x15c [raspberrypi_hwmon])
Aug 7 21:30:34 octopi kernel: [15480.943599] [] (get_values_poll [raspberrypi_hwmon]) from [] (process_one_work+0x170/0x458)
Aug 7 21:30:34 octopi kernel: [15480.943615] [] (process_one_work) from [] (worker_thread+0x5c/0x5a4)
Aug 7 21:30:34 octopi kernel: [15480.943630] [] (worker_thread) from [] (kthread+0x138/0x168)
Aug 7 21:30:34 octopi kernel: [15480.943645] [] (kthread) from [] (ret_from_fork+0x14/0x28)
Aug 7 21:30:34 octopi kernel: [15480.943656] Exception stack(0xef947fb0 to 0xef947ff8)
Aug 7 21:30:34 octopi kernel: [15480.943668] 7fa0: 00000000 00000000 00000000 00000000
Aug 7 21:30:34 octopi kernel: [15480.943681] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Aug 7 21:30:34 octopi kernel: [15480.943693] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Aug 7 21:30:34 octopi kernel: [15480.943706] INFO: task vcgencmd:3655 blocked for more than 120 seconds.
Aug 7 21:30:34 octopi kernel: [15480.943716] Tainted: G WC 4.19.75-v7l+ #1270
Aug 7 21:30:34 octopi kernel: [15480.943740] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 7 21:30:34 octopi kernel: [15480.943749] vcgencmd D 0 3655 1 0x00000005
Aug 7 21:30:34 octopi kernel: [15480.943780] [] (__schedule) from [] (schedule+0x50/0xa8)
Aug 7 21:30:34 octopi kernel: [15480.943799] [] (schedule) from [] (schedule_timeout+0x200/0x428)
Aug 7 21:30:34 octopi kernel: [15480.943817] [] (schedule_timeout) from [] (__down+0x98/0xec)
Aug 7 21:30:34 octopi kernel: [15480.943836] [] (__down) from [] (down+0x54/0x68)
Aug 7 21:30:34 octopi kernel: [15480.943857] [] (down) from [] (vchiq_release+0x160/0x354)
Aug 7 21:30:34 octopi kernel: [15480.943877] [] (vchiq_release) from [] (__fput+0xa4/0x1e8)
Aug 7 21:30:34 octopi kernel: [15480.943895] [] (__fput) from [] (____fput+0x18/0x1c)
Aug 7 21:30:34 octopi kernel: [15480.943913] [] (____fput) from [] (task_work_run+0xbc/0xe0)
Aug 7 21:30:34 octopi kernel: [15480.943933] [] (task_work_run) from [] (do_exit+0x3e0/0xc18)
Aug 7 21:30:34 octopi kernel: [15480.943951] [] (do_exit) from [] (do_group_exit+0x4c/0xe4)
Aug 7 21:30:34 octopi kernel: [15480.943970] [] (do_group_exit) from [] (get_signal+0x1a4/0x8cc)
Aug 7 21:30:34 octopi kernel: [15480.943987] [] (get_signal) from [] (do_signal+0x274/0x474)
Aug 7 21:30:34 octopi kernel: [15480.944002] [] (do_signal) from [] (do_work_pending+0xdc/0xf4)
Aug 7 21:30:34 octopi kernel: [15480.944016] [] (do_work_pending) from [] (slow_work_pending+0xc/0x20)
Aug 7 21:30:34 octopi kernel: [15480.944027] Exception stack(0xd91cbfb0 to 0xd91cbff8)
Aug 7 21:30:34 octopi kernel: [15480.944039] bfa0: fffffffc c01cc402 be9abbe4 00010001
Aug 7 21:30:34 octopi kernel: [15480.944053] bfc0: b6ee2404 b6ee2308 be9abc28 00000036 0001140c 000221e0 ffffffff 00000003
Aug 7 21:30:34 octopi kernel: [15480.944065] bfe0: b6ee2240 be9abbd4 b6ece928 b6de151c 60000010 00000003
Hope this helps
Does really nobody have an idea ? I mean it is really strange, that a specific printer-movement in x or y - direction causes the camera to crash. z-Movement does not affect anything. maybe @foosel has an idea how this might hang together ? It is reproduceable.
My last option might be is a complete new install from scratch.
Still hoping vor Ideas.
Best gregards
Try making sure your printer is not being back-powered from the Pi. Way to test: Turn printer power off, but leave Raspberry Pi on - does the LCD screen stay lit, or any lights on the printer motherboard?
I'm thinking maybe the printer sucks some power, which could cause the camera to crash.
There is a solution, and it is to tape over the 5V pin in USB cable. If you confirm the above, I can find the guide
hi @Charlie_Powell: when the Printer is off, the Display stays on.
Would be very kind of you to tell me where to find the guide :wink:
Thank you, I will try this evening and come back then.
Did you sort this out? I'm having the exact same problem. (camera crash when moving X,Y but not Z) . I have no 5v back-powering of the printer, so it should be something else.
For people having issues there in this youtube video DRVax shows a usb gadget of few bucks that solves the power issue if you dont want to mess with tape.
I solved my problem!
It had nothing to do with back powering as I already had taken care of that.
The problem was interference introduced to the 1m pi-cam ribbon cable, by running the cable to close to the stepper motors and their cables.
This in turn this caused out of spec signal to the board and crashed the camera. The separation needed to make it work was to far for my use case so I made some shielding kind of like this ( https://www.youtube.com/watch?v=8QgT8eiEgFU ) and it seems to work for now.
For the future I'm considering to use the shorter supplied cable for the cam and figure out a different mounting solution because I think 1m for that type of cable/use seems a bit dodgy.
Still don't know what the original posters problem was but if he still have issues and his config is like mine he might want to give shielding/shorter cable a try.
Hey ! Thanks for sharing this solution with us.
EMI, EMI everywhere … :man_facepalming: :smiley:
