Reset the ssh password on the pi
I can't remember what I used for the SSH password to the pi running OctoPrint. I didn't use one of my normal ones.
Is there a way to access the SD Card and set a new password without starting from scratch and setting up the system again?
NA
NA
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.2 Safari/605.1.15
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 1903308800
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.3
systeminfo.generator: zipapi
Bottom method of this post should work for you:
You may try this:
P.S.: The systeminfo bundle is not the systeminfo you posted, it is a zipped file. You stumbled over that download button before you clicked this tiny more...
Thanks. That bottom method is precisely what I was hoping for.
