Since updating Octoprint today, when I press "home" in controls, the machine makes a loud grating noise and I have to shut it off. Eventually showing "Machine Fault" error. This worked perfectly last night before update.
Interestingly this happens from any position once I press it. I can however move the axis manually in the Octoprint controls section and this works fine.
Nothing - not sure what to do next
X axis is the main culprit with the bed grinding as it moves when homing.
Z axis seems to move in the opposite direction. Problem is, when I move the controls the up and down are working as they should.
So I tried homing without octopi plugged in and getting the same type of homing errors. Does Octopi auto update the firmware of my printer as well as Octopi?
My printer is a Creality CR10s Pro. It also has BL touch 3 and it's been a long time but I believe I had to modify the firmware for that? I'm so out of the loop for how I set this up its been years.
Neither OctoPi nor OctoPrint update the firmware on the printer. The only thing that might affect the printer would be updated USB serial drivers, but that is unlikely.
I don't have an SD card in the slot, although to note my SD card slot has been damaged for a while now and I could only use octopi to send data to it. This has not been an issue in the past but possibly with this new octopi update it is now causing an issue?
Then again, that doesn't explain why its happened all of a sudden since doing the update if octopi does not modify the machines firmware.
I would agree with your final point, OctoPrint does not control how homing works on the printer so it would be unlikely that the OctoPrint update has impacted anything.
If the same issue happens when OctoPrint is disconnected (i.e. home from the printer's screen), then it is something to do with your printer firmware/hardware.
I'm now thinking its time to replace the motherboard, as it had that faulty sd card slot anyway. Maybe theres a more stable refresh by now for the CR10s Pro? V1
