Connecting OctoPrint to Creality CR10v3 control box sets bed to 9000 degrees as shown in OctoPrint and displays gibberish on the box screen. If I try to print, X goes out of range and firmware kills print. Everything worked OK before installing official Creality BLTouch firmware. Printer works fine from SD card.
### What did you already try to solve it?
Completely reinstalled Debian and OctoPrint. Changed USB cable (EDIT: with and without 5V pin blocked). Confirmed printer profile is correct. Tried printing newly sliced file and old one.
### Have you tried running in safe mode?
Yes.
### Did running in safe mode solve the problem?
No.
### Additional information about your setup
Operating System: Debian 11, LXQT, OpenBox. Computer Acer Aspire One D255 (Atom 1.66Ghz, 2GB Ram, 160GB HDD) Custom Anything: Created user "pi" to mimic raspbian install instructions/defaults, and enabled passwordless sudo. Installed Falkon browser. Everything else is stock. This computer isn't used for anything else.
Octoprint Version: 1.7.3 Non-Stock Plugins: Convert TF to SD (as prompted by OctoPrint); Simple Emergency Stop; OctoEverywhere!
I'm open to installing different firmware if it's already set up for BLTouch and relatively idiotproof. I've built PC's and have flashed a few Android ROM's but completely new to 3D printers.
It's more an issue with the printer's firmware than with OctoPrint.
First try to reflash the firmware again.
Then try with/without SD card in the printer. (I assume you took the original Creality firmware)
Also try this:
Thanks for the prompt response! Do you suggest using the same firmware, still flashed with CrealitySlicer, or is there some other/better option?
I forgot to mention that I've tried with and without 5V pin blocked. Had it blocked on the old USB cable (which worked fine before the upgrades/reinstall), isn't yet blocked on the new one. Both same result.
Decided I'd had it with Creality and jumped straight to a Marlin firmware that is working beautifully. For posterity, Cura wouldn't connect to the printer as a CR10, and had to be told there was a new "custom" machine before it would talk to it.
