I see
The OctoPrint server is currently not running
But there are no logs.
I know there are other duplicates of this issue, but I've tried the solutions I've found without luck.
- I kept the default username/password, pi/raspberry
- There was no ~/.octoprint/
- I checked and expanded the filesystem
pi@octopi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 15G 2.0G 12G 15% /
devtmpfs 55M 0 55M 0% /dev
tmpfs 183M 0 183M 0% /dev/shm
tmpfs 74M 940K 73M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/mmcblk0p1 255M 52M 204M 21% /boot
tmpfs 37M 0 37M 0% /run/user/1000
- I tried starting on safemode
server:
startOnceInSafeMode: true
- Upgraded
sudo apt update && sudo apt upgrade
- Tried random commands I saw online
pi@octopi:~ $ ~/oprint/bin/octoprint safemode
Illegal instruction
pi@octopi:~ $ ~/oprint/bin/octoprint serve
Illegal instruction
pi@octopi:~ $ ~/oprint/bin/octoprint serve --safe
Illegal instruction
pi@octopi:~ $ sudo ncdu /.
300.5 MiB [# ] /var
223.7 MiB [# ] /home
51.3 MiB [ ] /boot
17.1 MiB [ ] /opt
4.9 MiB [ ] /etc
944.0 KiB [ ] /run
52.0 KiB [ ] /root
48.0 KiB [ ] /tmp
e 16.0 KiB [ ] /lost+found
e 4.0 KiB [ ] /srv
e 4.0 KiB [ ] /mnt
e 4.0 KiB [ ] /media
0.0 B [ ] /sys
. 0.0 B [ ] /proc
0.0 B [ ] /dev
@ 0.0 B [ ] sbin
@ 0.0 B [ ] lib
@ 0.0 B [ ] bin
- Checked the permissions:
pi@octopi:~ $ ls -lh /var/log/
total 1.2M
-rw-r--r-- 1 root root 18K May 2 21:33 alternatives.log
drwxr-xr-x 2 root root 4.0K May 2 21:20 apt
-rw-r----- 1 root adm 7.8K May 2 21:47 auth.log
-rw-r--r-- 1 root root 0 Sep 22 2022 bootstrap.log
-rw-rw---- 1 root utmp 0 Sep 22 2022 btmp
-rw-r----- 1 root adm 158K May 2 21:47 daemon.log
-rw-r----- 1 root adm 4.0K May 2 21:46 debug
-rw-r--r-- 1 root root 232K May 2 21:35 dpkg.log
-rw-r--r-- 1 root root 24K Oct 27 2022 faillog
-rw-r--r-- 1 root root 484 Oct 27 2022 fontconfig.log
-rw-r----- 1 root adm 12K May 2 21:46 haproxy.log
drwxr-sr-x+ 3 root systemd-journal 4.0K Sep 22 2022 journal
-rw-r----- 1 root adm 112K May 2 21:46 kern.log
-rw-rw-r-- 1 root utmp 286K May 2 21:47 lastlog
-rw-r----- 1 root adm 137K May 2 21:46 messages
drwxr-xr-x 2 root adm 4.0K Oct 27 2022 nginx
drwx------ 2 root root 4.0K Sep 22 2022 private
drwxr-xr-x 3 root root 4.0K Sep 22 2022 runit
-rw-r----- 1 root adm 300K May 2 21:47 syslog
-rw-r----- 1 root adm 28K May 2 21:46 user.log
-rw-r--r-- 1 root root 49K May 2 21:46 webcamd.log
-rw-rw-r-- 1 root utmp 9.8K May 2 21:47 wtmp
Yes
Couldn't download it
**pi@octopi**:**~/.octoprint $** ~/oprint/bin/octoprint systeminfo .
Illegal instruction
Update about the illegal instruction
I tried this I found online. No luck yet:
source ~/oprint/bin/activate
(oprint) pi@octopi:~ $ pip3 uninstall -y numpy && pip3 install numpy==1.21.4
WARNING: Skipping numpy as it is not installed.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting numpy==1.21.4
Downloading https://www.piwheels.org/simple/numpy/numpy-1.21.4-cp39-cp39-linux_armv6l.whl (12.2 MB)
ββββββββββββββββββββββββββββββββββββββββ 12.2/12.2 MB 1.1 MB/s eta 0:00:00
Installing collected packages: numpy
Successfully installed numpy-1.21.4
[notice] A new release of pip available: 22.3 -> 24.0
[notice] To update, run: pip install --upgrade pip
(oprint) pi@octopi:~ $ sudo systemctl restart octoprint:
