- Chinese unbranded "HD" camera
 - Chinese unbranded 5mm endoscope
Both works correctly (tested on other machines)
I've successfully setup two webcams with the new camera-streamer stack  (following the post by foosel) and they works... sometimes. Even without rebooting the system or touching anything the webcams stop sending frames and Octoprint returns the following error response when issuing, for example, a GET /stream to octoprint.local:<port>
HTTP/1.1 500 Server Error
Content-Type: text/plain
Content-Length: 13
Server Error
No frames.
Note that the service is up and running as GET / returns the expected page
HTTP/1.1 200 OK
Content-Type: text/html
Content-Length: 2733
Access-Control-Allow-Origin: *
<!DOCTYPE html>
<html>
		<li>
			<a href="stream"><b>/stream</b></a> (MJPEG stream)</b><br>
			<br>
			<ul>
				<li>Get a live stream. Works everywhere, but consumes a ton of bandwidth.</li>
				<li>Uses resolution specified by <i>-camera-stream.height=</i>.</li>
			</ul>
		</li>
</body>
</html>
And the system service service is up and running (reporting the endoscope as an example but the same goes with the default service of the HD webcam)
pi@octoprint:~ $ sudo systemctl status camera-streamer-usb@endoscope.service
â—Ź camera-streamer-usb@endoscope.service - camera-streamer endoscope
     Loaded: loaded (/etc/systemd/system/camera-streamer-usb@.service; disabled; vendor preset: enabled)
    Drop-In: /etc/systemd/system/camera-streamer-usb@.service.d
             └─override.conf
     Active: active (running) since Thu 2024-03-07 18:37:23 CET; 3h 8min ago
TriggeredBy: â—Ź camera-streamer-usb-endoscope.path
    Process: 1114 ExecCondition=/bin/sh -c [ -e $DEVICE ] (code=exited, status=0/SUCCESS)
    Process: 1115 ExecCondition=/bin/sh -c ! ss -ltn src :$PORT | grep -q LISTEN (code=exited, status=0/SUCCESS)
   Main PID: 1118 (camera-streamer)
      Tasks: 19 (limit: 4915)
        CPU: 25.085s
     CGroup: /system.slice/system-camera\x2dstreamer\x2dusb.slice/camera-streamer-usb@endoscope.service
             └─1118 /usr/bin/camera-streamer --http-port=8081 --camera-type=v4l2 --camera-path=/dev/v4l/by-id/usb-Generic_HD_camera-video-index0 --camera-forma>
Mar 07 21:38:57 octoprint sh[1118]: util/http/http.c: HTTP8081/7: Client disconnected 192.168.1.187.
Mar 07 21:44:07 octoprint sh[1118]: util/http/http.c: HTTP8081/8: Client connected 192.168.1.187 (fd=12).
Mar 07 21:44:07 octoprint sh[1118]: util/http/http.c: HTTP8081/8: Request 'GET' '/stream' ''
Mar 07 21:44:09 octoprint sh[1118]: util/http/http.c: HTTP8081/8: Client disconnected 192.168.1.187.
Mar 07 21:45:06 octoprint sh[1118]: util/http/http.c: HTTP8081/9: Client connected 192.168.1.187 (fd=13).
Mar 07 21:45:06 octoprint sh[1118]: util/http/http.c: HTTP8081/9: Request 'GET' '/stream' ''
Mar 07 21:45:08 octoprint sh[1118]: util/http/http.c: HTTP8081/9: Client disconnected 192.168.1.187.
Mar 07 21:46:02 octoprint sh[1118]: util/http/http.c: HTTP8081/0: Client connected 192.168.1.187 (fd=4).
Mar 07 21:46:02 octoprint sh[1118]: util/http/http.c: HTTP8081/0: Request 'GET' '/stream' ''
Mar 07 21:46:04 octoprint sh[1118]: util/http/http.c: HTTP8081/0: Client disconnected 192.168.1.187.
lines 1-24/24 (END)
The issue does not arise consistently and if no one touch the system, after a while, the cameras might start to work again, after a non defined span of operative time, they randomly stops.
I've successfully printed for hours before they stopped working.
Even when both cams are accessed at the same time the CPU usage is low (under 5% on each core) and the cameras works nicely
I was trying to get a screenshot of it to post along with this but the endoscope frustratingly stopped working while I was about to capture the image -.-
I think this issue is related to Octoprint and the new camera stack and I'm thinking to roll-back to the old stack as this is getting hard to address.
As I didn't really debugged the issue myself I didn't want to open a new Issue on GitHub and was hoping that someone could know why this happens.
I already read about similar issues but the proposed solutions didn't work for me.
It would be nice to have a hint on how to debug this issue as octopi logs are not really helpful this time.
- Changed OPTIONS in config files (currently both have only
OPTIONS='--http-listen=0.0.0.0'set) - Restarted webcams and camera streamer in various ways (
systemctl restart camera-streamer,sudo camera-streamer-control restart,systemctl restart camera-streamer-usb@endoscope.service, etc... - Read realtime log
journalctl -fu camera-streamer\* - Different power supplies for Raspberry (from 15.0W, to 65W)
 - Switching USB ports (currently using USB 3.0 ports for both devices)
 - Restart Octoprint
systemctl restart octoprint.service - Reboot RPI
sudo shutdown now -r - Tried switching net interface from
wlan0,eth0. Currently using connection trough Ethernet cable
Yes, multiple times
No, it didn't. The issue persist without any difference in behaviour
octoprint-systeminfo-20240308004634.zip (67.6 KB)
- OctoPrint 1.9.3
 - Python 3.9.2
 - OctoPi* 1.0.0cam (build 2023.10.09.154319)
 - Original Prusa Mini
 - Official FW v5.1.2+13478
 - Mozilla Firefox Developer Edition for Arch Linux - 124.0b6 (64-bit)
