Just installed beta version 0.18.1 64 bit octopi on PI 4 8gb. Installed fine, wifi works. but when I do XY home or G28 from octoprint, x exis crash, try to go beyond x limit switch!! not sure why, Marlin should stoo that? Have not tried printig since can't do home. Printer is Ender 3 V2, Direct connecto to Cura to PC works. Through ocotprint don't work.
Tryied to connect Cura to Optoprint and tyried to do home, same results, crash in to X first and I stiop the printer. If I connect printer direclty then using Cura, homing works.
Complete Logs
Serial log:
2020-09-10 05:03:17,856 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 05:54:08,186 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:04:49,508 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:05:25,352 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:07:03,869 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:07:20,565 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:09:10,018 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:10:21,290 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-09-10 06:12:16,335 - Enabling serial logging
2020-09-10 06:12:17,000 - Recv: T:27.02 /0.00 B:27.22 /0.00 @:0 B@:0
2020-09-10 06:18:46,265 - Send: G28
2020-09-10 06:18:46,992 - Recv: T:27.27 /0.00 B:27.27 /0.00 @:0 B@:0
2020-09-10 06:18:48,270 - Recv: echo:busy: processing
2020-09-10 06:18:48,276 - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-09-10 06:18:48,992 - Recv: T:27.24 /0.00 B:27.30 /0.00 @:0 B@:0
2020-09-10 06:18:50,270 - Recv: echo:busy: processing
2020-09-10 06:18:50,992 - Recv: T:27.24 /0.00 B:27.27 /0.00 @:0 B@:0
2020-09-10 06:18:52,270 - Recv: echo:busy: processing
2020-09-10 06:18:52,992 - Recv: T:27.24 /0.00 B:27.24 /0.00 @:0 B@:0
2020-09-10 06:18:54,270 - Recv: echo:busy: processing
2020-09-10 06:18:54,992 - Recv: T:27.24 /0.00 B:27.27 /0.00 @:0 B@:0
2020-09-10 06:18:56,270 - Recv: echo:busy: processing
2020-09-10 06:18:56,992 - Recv: T:27.27 /0.00 B:27.27 /0.00 @:0 B@:0
2020-09-10 06:18:58,042 - Recv: Error:Printer halted. kill() called!
2020-09-10 06:18:58,044 - Changing monitoring state from "Operational" to "Error: Printer halted. kill() called!"
2020-09-10 06:18:58,047 - Send: M112
2020-09-10 06:18:58,055 - Send: N2 M112*35
2020-09-10 06:18:58,062 - Send: N3 M104 T0 S0*34
2020-09-10 06:18:58,064 - Send: N4 M140 S0*97
2020-09-10 06:18:58,094 - Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
2020-09-10 06:18:58,104 - Connection closed, closing down monitor
2020-09-10 06:26:20,756 - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-09-10 06:26:20,782 - Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2020-09-10 06:26:20,783 - Trying port /dev/ttyUSB0, baudrate 115200
2020-09-10 06:26:20,783 - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-09-10 06:26:20,840 - Handshake attempt #1 with timeout 2.0s
2020-09-10 06:26:20,842 - Connected to: Serial<id=0x7f8219dfd0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-09-10 06:26:20,843 - Send: N0 M110 N0*125
2020-09-10 06:26:20,849 - Recv: ok
2020-09-10 06:26:20,851 - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-09-10 06:26:20,858 - Send: N0 M110 N0*125
2020-09-10 06:26:20,863 - Recv: ok
2020-09-10 06:26:20,864 - Send: N1 M115*39
2020-09-10 06:26:20,902 - Recv: FIRMWARE_NAME:Marlin 2.0.6.1 (Sep 4 2020 02:22:30) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 V2 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-09-10 06:26:20,907 - Recv: Cap:SERIAL_XON_XOFF:0
2020-09-10 06:26:20,918 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-09-10 06:26:20,921 - Recv: Cap:EEPROM:1
2020-09-10 06:26:20,930 - Recv: Cap:VOLUMETRIC:1
2020-09-10 06:26:20,932 - Recv: Cap:AUTOREPORT_TEMP:1
2020-09-10 06:26:20,935 - Recv: Cap:PROGRESS:0
2020-09-10 06:26:20,953 - Recv: Cap:PRINT_JOB:1
2020-09-10 06:26:20,955 - Recv: Cap:AUTOLEVEL:1
2020-09-10 06:26:20,958 - Recv: Cap:RUNOUT:0
2020-09-10 06:26:20,959 - Recv: Cap:Z_PROBE:1
2020-09-10 06:26:20,962 - Recv: Cap:LEVELING_DATA:1
2020-09-10 06:26:20,964 - Recv: Cap:BUILD_PERCENT:0
2020-09-10 06:26:20,971 - Recv: Cap:SOFTWARE_POWER:0
2020-09-10 06:26:20,983 - Recv: Cap:TOGGLE_LIGHTS:0
2020-09-10 06:26:20,986 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-09-10 06:26:20,998 - Recv: Cap:EMERGENCY_PARSER:0
2020-09-10 06:26:21,007 - Recv: Cap:PROMPT_SUPPORT:0
2020-09-10 06:26:21,012 - Recv: Cap:SDCARD:1
2020-09-10 06:26:21,015 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-09-10 06:26:21,018 - Recv: Cap:LONG_FILENAME:0
2020-09-10 06:26:21,021 - Recv: Cap:THERMAL_PROTECTION:1
2020-09-10 06:26:21,025 - Recv: Cap:MOTION_MODES:0
2020-09-10 06:26:21,027 - Recv: Cap:ARCS:1
2020-09-10 06:26:21,031 - Recv: Cap:BABYSTEPPING:1
2020-09-10 06:26:21,034 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-09-10 06:26:21,037 - Recv: ok
2020-09-10 06:26:21,038 - Send: M21
2020-09-10 06:26:22,273 - Recv: echo:No SD card
2020-09-10 06:26:22,276 - Recv: ok
2020-09-10 06:26:22,278 - Send: M876 P1
2020-09-10 06:26:22,283 - Recv: echo:Unknown command: "M876 P1"
2020-09-10 06:26:22,286 - Recv: ok
2020-09-10 06:26:22,287 - Send: M420V1
2020-09-10 06:26:22,291 - Recv:
2020-09-10 06:26:22,292 - Recv: Bed Topography Report:
2020-09-10 06:26:22,302 - Recv: ( 10,215) (235,215)
2020-09-10 06:26:22,317 - Recv: 0 1 2 3 4 5 6 7 8 9 10 11
2020-09-10 06:26:22,326 - Recv: 11 | +0.038 +0.026 +0.014 +0.002 -0.019 -0.024 -0.053 -0.069 -0.064 -0.016 +0.031 +0.078
2020-09-10 06:26:22,326 - Recv: |
2020-09-10 06:26:22,334 - Recv: 10 | +0.038 +0.026 +0.014 +0.002 -0.019 -0.024 -0.053 -0.069 -0.064 -0.016 +0.031 +0.078
2020-09-10 06:26:22,335 - Recv: |
2020-09-10 06:26:22,343 - Recv: 9 | +0.038 +0.026 +0.014 +0.002 -0.019 -0.024 -0.053 -0.069 -0.064 -0.016 +0.031 +0.078
2020-09-10 06:26:22,343 - Recv: |
2020-09-10 06:26:22,354 - Recv: 8 | +0.094 +0.068 +0.042 +0.016 -0.002 -0.011 -0.027 -0.042 -0.025 +0.010 +0.045 +0.081
2020-09-10 06:26:22,355 - Recv: |
2020-09-10 06:26:22,363 - Recv: 7 | +0.044 +0.044 +0.044 +0.055 -0.000 -0.009 -0.039 -0.035 -0.015 +0.005 +0.026 +0.047
2020-09-10 06:26:22,363 - Recv: |
2020-09-10 06:26:22,371 - Recv: 6 | +0.049 +0.049 +0.049 +0.049 +0.021 -0.009 -0.050 -0.049 -0.030 -0.015 -0.001 +0.013
2020-09-10 06:26:22,372 - Recv: |
2020-09-10 06:26:22,383 - Recv: 5 | +0.116 +0.086 +0.055 +0.024 +0.016 +0.008 -0.061 -0.070 -0.018 +0.014 +0.047 +0.079
2020-09-10 06:26:22,383 - Recv: |
2020-09-10 06:26:22,391 - Recv: 4 | +0.080 +0.068 +0.057 +0.045 +0.028 +0.008 -0.034 -0.056 -0.008 +0.011 +0.030 +0.050
2020-09-10 06:26:22,392 - Recv: |
2020-09-10 06:26:22,400 - Recv: 3 | +0.135 +0.101 +0.067 +0.033 +0.016 +0.000 -0.032 -0.043 -0.029 -0.015 -0.002 +0.011
2020-09-10 06:26:22,400 - Recv: |
2020-09-10 06:26:22,408 - Recv: 2 | +0.087 +0.066 +0.045 +0.023 +0.008 -0.002 -0.027 -0.035 -0.023 -0.001 +0.021 +0.043
2020-09-10 06:26:22,411 - Recv: |
2020-09-10 06:26:22,420 - Recv: 1 | +0.087 +0.066 +0.045 +0.023 +0.008 -0.002 -0.023 -0.028 -0.018 +0.013 +0.045 +0.076
2020-09-10 06:26:22,420 - Recv: |
2020-09-10 06:26:22,428 - Recv: 0 | +0.087 +0.066 +0.045 +0.023 +0.008 -0.002 -0.018 -0.020 -0.012 +0.028 +0.068 +0.108
2020-09-10 06:26:22,444 - Recv: 0 1 2 3 4 5 6 7 8 9 10 11
2020-09-10 06:26:22,454 - Recv: ( 10, 10) (235, 10)
2020-09-10 06:26:22,457 - Recv: Mesh is valid
2020-09-10 06:26:22,457 - Recv: Storage slot: 0
2020-09-10 06:26:22,459 - Recv: echo:Bed Leveling OFF
2020-09-10 06:26:22,462 - Recv: echo:Fade Height 10.00
2020-09-10 06:26:22,464 - Recv: ok
2020-09-10 06:26:22,466 - Send: M851
2020-09-10 06:26:22,472 - Recv: Probe Offset X-30.00 Y-2.00 Z-1.30
2020-09-10 06:26:22,472 - Recv: ok
2020-09-10 06:26:22,473 - Send: M155 S2
2020-09-10 06:26:22,477 - Recv: ok
2020-09-10 06:26:24,482 - Recv: T:27.27 /0.00 B:27.33 /0.00 @:0 B@:0
2020-09-10 06:26:26,482 - Recv: T:27.27 /0.00 B:27.33 /0.00 @:0 B@:0
OctoPrint version 1.4.2, OctoPi version 0.18.1, printer, firmware Marlin 2.6.1, browser, operating system W10, Printer Ender 3 V2
