I hope you can help me - I am really new in 3D printing abd octopi/octoprint. About one week ago I finished my Prus i3 MK3S+. The first 20 printes are perfekt (for me at least). Then I read about octopi and I thought that is pretty cool.
I installed everything - typed in the measurements and everything worked. So time to test the first print.
Here is my problem - when I start a print from Octopi my Prusa Y axis crashes in the back. So I stoped the print - unplugged the pi from the printer - copied the file on the sd card - started the print from the sd card - crashed again - so I let the printer cool down - shut it off - started the print from the sd card again - works like a charm again - I double checked my settings - I cant find the problem and I am afraid from trying all the time - It cant be cood to crash all the time...
I downloaded the file and used the prusa slicer - like I wrote above the strange thing is that from the sd card it didn't happen.
I can't upload the G-Code it is too big
Hmm I cant answer this question to be honest... I just installed and did nothing else... do I have to?
befor when I used only the SD card the printer always did a bed leveling.
The gcode seems to be ok.
You may slice a small cube and try with that.
Before that you may enable the serial.log so that we can see what is going on with the USB connection.
I dont understand this "Before that you may enable the serial.log so that we can see what is going on with the USB connection." means print the cube first? or can I download the serial.log before? do you speak german?
Ja, tue ich
Also, bevor Du den kleinen Würfel druckst könntest Du das serial.log aktivieren.
Dann werden alle Daten aufgezeichnet, die zwischen OctoPrint und dem Drucker ausgetauscht werden.
Wenn es beim Druck des Würfels keine Probleme gibt ist es gut.
Dann könntest DU nochmal das andere Modell drucken. Dann gibt es genauere Daten was kurz vor dem Crash passiert.
Manchmal verhält sich die Prusa Firmware zusammen mit OctoPrint etwas komisch.
ok da tue ich mir mal um einiges leichter - danke
ok das habe ich aktiviert - jetzt habe ich so einen würfel raufgeladen und dann kam so eine fehlermeldung das der würfel zu groß sei obwohl er nur 20mm groß ist - und im slicer sieht man das, dass er sehr klein ist.
kann das die ursache sein?
