I cannot reach the website for my octopi nor can I connect to it via ssh. It worked yesterday evening. I was working on connecting it to my Ender 3 V2, so I had to get a firmware update. Once I finished that I worked on getting my FujiFilm X-T10 synced up with it via Gphoto2. Gphoto said that i needed to run "sudo apt-get updates" and I did. It worked and it ended up syncing up with Octoprint. At that point it was 00:30 in the night so I powered off everything and went to bed. When I woke up this morning OctoPi wouldn't work.
I have tried reflashing
Changing name of the raspberry pi
Connecting it to my secondary WiFi
Connecting to it via the IP adress
Rebooting both internet, computer and raspberry pi
Unplug and plug cable back in
Tried connecting to it via a monitor and keyboard, and then logging in manually
Ender 3 V2 (I haven't even connected this so this is not a factor)
Raspberry Pi 3B+
Using Windows for ssh and downloading. Using OctoPi version 0.17.0 and OctoPrint version 1.3.12 on my Pi
Thanks!
