When I click print, nothing happens.
Tried running in safe mode, pid tuning, reinstalling OctoPi
Yes
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
haproxy.log  (19.8 KB)octoprint.log  (21.8 KB)plugin_pluginmanager_console.log  (11.8 KB)serial.log  (148 Bytes)webcamd.log  (2.6 KB)
Ender 3 Pro, OctoPi, Raspberry Pi 3B+
              You have an issue with the connection.
Also read this post
    A lot of resend requests or a high resend ratio in OctoPrint can be quite a problem when trying to reliably print.
For Creality Ender3s - apart from the usual suspects  - this can apparently also be caused by the LCD cable, as user @flrnwgnr  reported . To quote:
The day before i printed a drawer and pushed the cable for the LCD just behind it - like this:
 [Cabling before]
And that was the problem! After i re-arranged the cable according to the picture below (as I had it before and as β¦
Please enable serial logging so we know what's going going on if the connection fails again
              Hi! Thanks for responding! Just now trying to do what you showed me I started getting this when connecting State: Offline after error
              For it's a Creality machine try with/without SD card in the printer and/or this:
    First of all this whole tutorial isn't a mandatory mod - you just need it if you run into issues (weird things are happening and you've already ruled out the more common suspects) or if the always running fan and illuminated display (even when the printer is turned off) disturbes you.
I'm starting with the why part:
If you connect a 3D printer via USB to your Raspberry Pi it can lead to all sorts of power related issues.
Most of the time those issues occur only if you turn on your pi before β¦
                system
                    May 17, 2022,  4:06am
                  5
