Connecting to an Ender 7
Hi everyone,
I'm hoping someone can help me.
I have searched the forum and can't see any similar questions
I've installed Octopi on a Pi4 and can connect to it with no problems.
I can't get Octopi to connect to my Ender 7.
I gone through all the dialogs and changed the serial port from/to "/dev/ttyUSB0" and "/tmp/printer" rebooting.
I'm getting the error "option 'serial' in section 'mcu' must be specified". I can't see that option anywhere.
Anyone help please?
Cheers
Fatso.
Hello @Fatso !
As good as we can, but for help, please use the sub-forum Get Help. (I'll move it for you).
But please in this template:
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, .... as much data as possible
For it is a Crealty printer try with/with out the SD card in the printer and also this:
I've installed Octoprint on a Pi4 and can connect to it with no problems.
I can't get Octopprint to connect to me Ender 7.
From the Terminal-
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /tmp/printer, baudrate 250000
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xac3be750, open=True>(port='/tmp/printer', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: ok
Send: N0 M110 N0
125
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N0 M110 N0125
Recv: ok
Send: N1 M115
39
Recv: ok FIRMWARE_VERSION:4c8d24a FIRMWARE_NAME:Klipper
Send: M21
Recv: ok
Send: M105
Recv: ok T:0
Send: M105
I've gone through all the dialogs and changed the serial port from/to "/dev/ttyUSB0" and "/tmp/printer" rebooting.
Yes
No - No difference
octoprint-systeminfo-20220218204908.zip (1.6 MB)
OctoPrint 1.7.3, OctoPi 0.18.0, Creality Ender 7 Firmware 1.0.20T
When you were trying to install OctoPrint on your SD card you selected the wrong image in the Raspberry Pi imager.
Just install the regular 'OctoPi' image, not 'OctoPi-Klipper' which will only work if you have installed Klipper fimware on your printer.
Thank you I'm on the case.
When I went into the Pi Imager I could see that the version with Klipper was already downloaded.
I'll confirm.
Hi Charlie, That's all sorted.
Thanks for your help.
Cheers
Fatso!
Love your alias. Just so you know. :slight_smile:
The Ender 7 is a wonderful printer. I hope you enjoy it!
