OctoPi not printing
Hello @vbbartlett!
Please don't hijack a thread with a different problem. It seems you have connection issues.
@wormpower obviously has a slicer problem.
Please open a new thread and fill in the template that appears.
@Ewald_Ikemann
I haven’t changed anything.
I’ve tried to set temp in octopi then hit print. Temp stops heating.
Tried printing via saved file in octopi, or from cuta.
It always ends up with printer canceling.
No update to cura. And no change to file
Please don't mix up OctoPrint and OctoPi:
You may use M109/M190 instead of M104/M140 because the first ones wait until the temperature is reached. And don't forget to set the proper temperatures to these commands.
Can you share the start gcode you use in cura?
i was mistaken, there was an update to cura
but below is the updated terminal output
Recv: T:23.59 /0.00 B:23.81 /0.00 @:0 B@:0
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110 N0125
Recv: ok N0 P15 B4
Changing monitoring state from "Starting" to "Printing"
Changing monitoring state from "Printing" to "Cancelling"
Send: N1 M82
24
Recv: ok N1 P15 B4
Send: N2 M10840
Recv: echo:Unknown command: "M108"
Recv: ok N2 P15 B4
Send: N3 M84
28
Recv: ok N3 P15 B4
Send: N4 M104 T0 S037
Recv: ok N4 P15 B4
Send: N5 M140 S0
96
Recv: ok N5 P15 B4
Send: N6 M106 S0*97
Recv: ok N6 P15 B4
Changing monitoring state from "Cancelling" to "Operational"
Recv: T:23.47 /0.00 B:23.70 /0.00 @:0 B@:0
Recv: T:23.50 /0.00 B:23.77 /0.00 @:0 B@:0
Recv: T:23.44 /0.00 B:23.70 /0.00 @:0 B@:0
Recv: T:23.41 /0.00 B:23.67 /0.00 @:0 B@:0
@Ewald_Ikemann
heres start code
;This G-Code has been generated specifically for the LulzBot TAZ 6 with MOARstruder
M73 P0 ; clear GLCD progress bar
M75 ; start GLCD timer
G26 ; clear potential 'probe fail' condition
M107 ; disable fans
M420 S0 ; disable previous leveling matrix
G90 ; absolute positioning
M82 ; set extruder to absolute mode
G92 E0 ; set extruder position to 0
M140 S{material_bed_temperature_layer_0} ; start bed heating up
M109 R{material_soften_temperature} ; soften filament before homing Z
G28 ; Home all axis
G1 E-30 F100 ; retract filament
M109 R{material_wipe_temperature} ; wait for extruder to reach wiping temp
G1 X-15 Y100 F3000 ; move above wiper pad
G1 Z1 ; push nozzle into wiper
G1 X-17 Y95 F1000 ; slow wipe
G1 X-17 Y90 F1000 ; slow wipe
G1 X-17 Y85 F1000 ; slow wipe
G1 X-15 Y90 F1000 ; slow wipe
G1 X-17 Y80 F1000 ; slow wipe
G1 X-15 Y95 F1000 ; slow wipe
G1 X-17 Y75 F2000 ; fast wipe
G1 X-15 Y65 F2000 ; fast wipe
G1 X-17 Y70 F2000 ; fast wipe
G1 X-15 Y60 F2000 ; fast wipe
G1 X-17 Y55 F2000 ; fast wipe
G1 X-15 Y50 F2000 ; fast wipe
G1 X-17 Y40 F2000 ; fast wipe
G1 X-15 Y45 F2000 ; fast wipe
G1 X-17 Y35 F2000 ; fast wipe
G1 X-15 Y40 F2000 ; fast wipe
G1 X-15 Y30 Z2 F2000 ; fast wipe
G1 X-15 Y25 F2000 ; fast wipe
G1 X-17 Y30 F2000 ; fast wipe
G1 X-15 Y25 Z1.5 F1000 ; slow wipe
G1 X-17 Y23 F1000 ; slow wipe
G1 Z10 ; raise extruder
M109 R{material_probe_temperature} ; wait for extruder to reach probe temp
G1 X-9 Y-9 ; move above first probe point
M204 S100 ; set probing acceleration
G29 ; start auto-leveling sequence
M420 S1 ; activate bed level matrix
M425 Z ; use measured Z backlash for compensation
M425 Z F0 ; turn off measured Z backlash compensation. (if activated in the quality settings, this command will automatically be ignored)
M204 S500 ; restore standard acceleration
G1 X0 Y0 Z15 F5000 ; move up off last probe point
G4 S1 ; pause
M400 ; wait for moves to finish
M117 Heating... ; progress indicator message on LCD
M109 R{material_print_temperature_layer_0} ; wait for extruder to reach printing temp
M190 R{material_bed_temperature_layer_0} ; wait for bed to reach printing temp
G1 Z2 E0 F75 ; prime tiny bit of filament into the nozzle
M117 TAZ 6 Printing... ; progress indicator message on LCD
This looks pretty much like this one:
From the post before I can say, that there is no heating established.
You may preheat from OctoPrint with this:
You also can use the Preheat plugin:
This takes the values from the file that is to be printed.
@Ewald_Ikemann
i tried preheating with both methods
as soon as i print it kills temp
Recv: T:114.38 /0.00 B:41.23 /0.00 @:0 B@:0
Recv: T:113.78 /0.00 B:41.30 /0.00 @:0 B@:0
Recv: T:113.27 /0.00 B:41.28 /0.00 @:0 B@:0
Send: M140 S45
Recv: ok P15 B4
Send: M141 S0
Recv: echo:Unknown command: "M141 S0"
Recv: ok P15 B4
Send: M104 S140
Recv: ok P15 B4
Recv: T:112.80 /140.00 B:41.28 /45.00 @:127 B@:103
Recv: T:112.45 /140.00 B:41.89 /45.00 @:127 B@:103
Recv: T:112.70 /140.00 B:42.51 /45.00 @:127 B@:103
Recv: T:113.54 /140.00 B:42.91 /45.00 @:127 B@:103
Recv: T:114.79 /140.00 B:43.50 /45.00 @:127 B@:90
Recv: T:116.37 /140.00 B:44.00 /45.00 @:127 B@:66
Recv: T:118.11 /140.00 B:44.33 /45.00 @:127 B@:62
Recv: T:119.93 /140.00 B:44.72 /45.00 @:127 B@:42
Recv: T:122.23 /140.00 B:44.89 /45.00 @:127 B@:44
Recv: T:124.46 /140.00 B:45.15 /45.00 @:127 B@:24
Recv: T:126.62 /140.00 B:45.17 /45.00 @:127 B@:31
Recv: T:128.70 /140.00 B:45.34 /45.00 @:127 B@:12
Recv: T:130.85 /140.00 B:45.27 /45.00 @:127 B@:25
Recv: T:133.31 /140.00 B:45.31 /45.00 @:126 B@:17
Recv: T:135.50 /140.00 B:45.25 /45.00 @:102 B@:21
Recv: T:137.55 /140.00 B:45.29 /45.00 @:69 B@:12
Recv: T:139.35 /140.00 B:45.17 /45.00 @:33 B@:25
Recv: T:141.17 /140.00 B:45.22 /45.00 @:0 B@:12
Recv: T:142.33 /140.00 B:45.27 /45.00 @:0 B@:0
Recv: T:143.11 /140.00 B:45.13 /45.00 @:0 B@:15
Recv: T:143.42 /140.00 B:45.22 /45.00 @:0 B@:0
Send: N0 M110 N0125
Recv: ok N0 P15 B4
Changing monitoring state from "Starting" to "Cancelling"
Changing monitoring state from "Cancelling" to "Printing"
Send: N1 M108
43
Recv: ok N1 P15 B4
Send: N2 M8429
Recv: ok N2 P15 B4
Send: N3 M82
26
Recv: ok N3 P15 B4
Recv: ok N4 P15 B4
Send: N5 M140 S0
96
Recv: ok N5 P15 B4
Send: N6 M106 S0*97
Recv: ok N6 P15 B4
Changing monitoring state from "Printing" to "Operational"
Recv: T:143.46 /0.00 B:45.01 /0.00 @:0 B@:0
Recv: T:143.33 /0.00 B:44.89 /0.00 @:0 B@:0
Recv: T:142.93 /0.00 B:44.80 /0.00 @:0 B@:0
Recv: T:142.53 /0.00 B:44.70 /0.00 @:0 B@:0
Recv: T:142.07 /0.00 B:44.65 /0.00 @:0 B@:0
Recv: T:141.47 /0.00 B:44.51 /0.00 @:0 B@:0
Because in this section you set the temperature with the value S0 to 0 (zero) again.
i didnt change it, it changed as soon as i hit print
What is this short 6 liner you want to "print"? There is nothing to print in it.
I just looks like an End Gcode script.
sorry i dont understand this question, im still pretty new to gcode.
below is output from hitting print in cura, uptill now ive been hitting print within octoprint
Recv: T:139.81 /140.00 B:45.05 /45.00 @:35 B@:11
Recv: T:139.49 /140.00 B:44.94 /45.00 @:47 B@:25
Recv: T:139.29 /140.00 B:44.96 /45.00 @:55 B@:23
Recv: T:139.18 /140.00 B:45.03 /45.00 @:62 B@:13
Recv: T:139.33 /140.00 B:44.92 /45.00 @:58 B@:27
Recv: T:139.52 /140.00 B:44.98 /45.00 @:54 B@:20
Recv: T:139.89 /140.00 B:45.06 /45.00 @:41 B@:8
Recv: T:140.21 /140.00 B:44.94 /45.00 @:31 B@:25
Recv: T:140.60 /140.00 B:44.96 /45.00 @:16 B@:24
Recv: T:140.95 /140.00 B:45.06 /45.00 @:0 B@:8
Recv: T:141.09 /140.00 B:45.10 /45.00 @:0 B@:3
Recv: T:141.02 /140.00 B:44.98 /45.00 @:1 B@:20
Send: N0 M110 N0125
Send: N1 M108
43
Recv: ok N0 P15 B4
Recv: ok N1 P15 B4
Send: N2 M8429
Recv: ok N2 P15 B4
Send: N3 M104 T0 S0
34
Recv: ok N3 P15 B4
Send: N4 M140 S097
Recv: ok N4 P15 B4
Send: N5 M106 S0
98
Recv: ok N5 P15 B4
Recv: T:140.81 /0.00 B:44.96 /0.00 @:0 B@:0
Recv: T:140.40 /0.00 B:44.87 /0.00 @:0 B@:0
Recv: T:139.98 /0.00 B:44.85 /0.00 @:0 B@:0
Recv: T:139.48 /0.00 B:44.70 /0.00 @:0 B@:0
Recv: T:138.97 /0.00 B:44.61 /0.00 @:0 B@:0
Recv: T:138.45 /0.00 B:44.51 /0.00 @:0 B@:0
Recv: T:137.93 /0.00 B:44.45 /0.00 @:0 B@:0
Recv: T:137.38 /0.00 B:44.52 /0.00 @:0 B@:0
Recv: T:136.72 /0.00 B:44.33 /0.00 @:0 B@:0
Recv: T:136.21 /0.00 B:44.18 /0.00 @:0 B@:0
Recv: T:135.54 /0.00 B:44.00 /0.00 @:0 B@:0
Recv: T:135.00 /0.00 B:43.95 /0.00 @:0 B@:0
Recv: T:134.30 /0.00 B:43.83 /0.00 @:0 B@:0
Recv: T:133.66 /0.00 B:43.90 /0.00 @:0 B@:0
So I recommend this site:
https://www.reprap.org/wiki/G-code
With this you can "decode" the lines of a Gcode file.
Actually, the file you want to print contains no data that can be printed.
You can recognize them by a G1 at the start.
Have you tried to slice your model again?
@Ewald_Ikemann
this is a fresh slice
Recv: T:108.49 /0.00 B:38.65 /0.00 @:0 B@:0
Recv: T:108.06 /0.00 B:38.52 /0.00 @:0 B@:0
Recv: T:107.55 /0.00 B:38.42 /0.00 @:0 B@:0
Recv: T:107.12 /0.00 B:38.60 /0.00 @:0 B@:0
Recv: T:106.62 /0.00 B:38.50 /0.00 @:0 B@:0
Recv: T:106.14 /0.00 B:38.35 /0.00 @:0 B@:0
Send: N0 M110 N0125
Send: N1 M108
43
Recv: ok N0 P15 B4
Recv: ok N1 P15 B4
Send: N2 M8429
Recv: ok N2 P15 B4
Send: N3 M104 T0 S0
34
Recv: ok N3 P15 B4
Send: N4 M140 S097
Recv: ok N4 P15 B4
Send: N5 M106 S0
98
Recv: ok N5 P15 B4
Recv: T:105.67 /0.00 B:38.40 /0.00 @:0 B@:0
Recv: T:105.19 /0.00 B:38.27 /0.00 @:0 B@:0
Recv: T:104.74 /0.00 B:38.38 /0.00 @:0 B@:0
There is still nothing in it.
Maybe the model is broken. You may try another model.
Or somthing is messed up with your Cura settings.
@Ewald_Ikemann
this is a different model
Recv: T:61.33 /0.00 B:34.94 /0.00 @:0 B@:0
Recv: T:61.17 /0.00 B:34.92 /0.00 @:0 B@:0
Recv: T:60.98 /0.00 B:34.89 /0.00 @:0 B@:0
Recv: T:60.82 /0.00 B:34.97 /0.00 @:0 B@:0
Recv: T:60.66 /0.00 B:34.83 /0.00 @:0 B@:0
Send: N0 M110 N0125
Recv: ok N0 P15 B4
Send: N1 M108
43
Recv: ok N1 P15 B4
Send: N2 M8429
Recv: ok N2 P15 B4
Send: N3 M104 T0 S0
34
Recv: ok N3 P15 B4
Send: N4 M140 S097
Recv: ok N4 P15 B4
Send: N5 M106 S0
98
Recv: ok N5 P15 B4
Recv: T:60.41 /0.00 B:34.58 /0.00 @:0 B@:0
Recv: T:60.26 /0.00 B:35.02 /0.00 @:0 B@:0
Recv: T:59.99 /0.00 B:34.53 /0.00 @:0 B@:0
Recv: T:59.85 /0.00 B:34.78 /0.00 @:0 B@:0
Recv: T:59.62 /0.00 B:34.56 /0.00 @:0 B@:0
There is also nothing in it.
Have you checked the Cura profiles are still correct?
@Ewald_Ikemann
firstly thank you for trying to help me
sadly i created a new cura profile and still doesnt work.
2 days ago it printed the files in octoprints file history.
not changed anything between then and now
As long there are proper files on OctoPrint, you still can print them
@Ewald_Ikemann
just for giggles, i sent this file to my 2nd printer i have setup the same
and its printing.
so something with first print
just no idea what
Have you tried with safe mode on OctoPrint?
