Octopi won't connect if plugged into ender 3 v2 prior to ender powered on
Octoprint will only connect to ender 3 V2 as long as the ender is powered up first and then the raspberry pi gets plugged in second.
Starting the ender then plugging in the pi allows the ender to do a hard reset of the baudrate but does not allow me to keep the pi plugged in.
Yes i have tried safe mode with no change.
No change with safe mode.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.164 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 1
env.hardware.freq: 1000
env.hardware.ram: 386322432
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi Zero W Rev 1.1
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.6.1
printer.firmware: Marlin E3V2-Extensible-UI (Jun 6 2021 13:54:35)
Hello @Steve05
Could you please share the bundle?
You find the systeminfo bundle below the systeminfo. It's a zipped file.
Backpowering is likely the issue. Try this:
This will mean the printer is not affected by plugging in the Pi before it is turned on.
Thank you everyone that tried to help. As of today, I had an octoprint update alert and I upgraded it and this seems to have fixed the problem. I am unsure on what the upgrade was as the version of octoprint still reads as 1.6.1.
Sorry to have not replied to this before but I have already had the tape mod applied to the USB and that did not change the outcome.
Here is the system bundle once it has been fixed.
octoprint-systeminfo-20210806022819.zip (13.5 KB)
Interesting, the errors in the log indicate that your printer stops responding.
I have noticed that but it has never affected the prints in any way once it is properly connected.
