Octoprint crashing after print completes unable to access through IP after crash need to access through ssh and restart the octoprint service to regain access. When it crashes and i try to access the ip i get that screen "The OctoPrint server is currently not running" with some code to run like "Verify that the process is running: ps -ef | grep -i octoprint | grep -i python should show a python process:"
I tried a different Raspberry PI 3 Model B, reinstalled entire octoprint from scratch and it worked for 2 days then started to crash again. prior to fresh install it was shutting down immediately after print the bed didn't even get a chance to move to front. This i feel was a issue with PSU control in some way but that was corrected after new install. I have log files ready if needed. Thank you
I have not but with it running completely fine after new install i am nearly 100% positive in safe mode this will not be a issue. I suspect a plugin error possibly Spaghetti detective as that is the last code that pops up in logs before crash.
octoprint-systeminfo-20211112124917.zip (246.3 KB)
