Pi Undervoltage/power issues: I had a strange lightning bolt/temperature symbol with an exclamation mark popup in my navbar, what does that mean?
OctoPrint itself doesn't measure the voltage or produce that error. It's a tool provided by the Raspberry Pi Foundation itself that's saying your Pi us running without sufficient voltage.
The warning comes from the bundled Pi Support plugin. If you want to disable it without fixing the underlying issue (and if the aforementioned tool says there is an issue there is an issue because your Pi will run throttled and there's nothing OctoPrint can do to change that fact), then disable that plugin at your own risk.
Thanks Foosel, I will look if I can find this plugin
But it is killing me to understand WHY the pi is sending back under power message, when the log on the USB power shows that the USB power supply is good see pict below
You may log this data during powering up. Also just in between two of the measuring points, the Pi need some more power the PS can provide - even for a few milliseconds -, the undervoltage alert is triggered.
And when the Raspberry Pi Foundation strongly recommends to use a power supply rated 5.1V / 2.5A, you really should do. Everything else is a workaround and will lead to major issues sooner or later, up to write errors to the SD card etc...
Also there is a slight chance that there is something wrong with the Pi itself.
Hi
I have the powering up date, several one, and 10 of hours of logs, if it was a millisecond, I should statistically record it once in a while
I have an other Pi running my house automation, I will shut it down and have a quick swap to see if the rapsberry 2 running octoprint is faulty. I really dont want to buy an other power supply if I must not to. Saving a cubic meter of earth at a time
A long time ago, the Air Force sent me away to a really wonderful two weeks of training. One of the tasks was to (laboriously) design power supply circuits. If you could see all this on charts and oscilloscopes it might be easier to understand. But you have to trust me if I tell you that a 5V 2.5A power adapter is the requirement.
Just a "FWIW" post...
I encountered an undervoltage early on using a non-RPi power supply and doing both of these two things fixed it:
  • disconnecting the RPi camera
  • cutting the +DC conductor on the only USB cable plugged into the RPi
Recently I decided to power the RPi with a buck converter. I set the output to 5.1VDC and soldered the teensy wires from a micro USB cable to it. With or without the RPi camera, I got more undervoltage errors showing on OctoPi.
The fix: I swapped the micro USB cable out for 20 AWG wiring and powered RPi +5V and ground pins directly. It would be far more convenient if I could find a micro USB plug with heavy enough conductors, but for now this is working fine with the RPi camera.
How much current can it deliver?
3A, I believe.
The point is, the sole issue was wire gauge.
I know I've talked about wire gauge on here and provided external links and references to the USB power spec itself.
Im getting overheat on a canakit gen 1 pi4 4gb sitting idle, this seems odd, only thing I can think of is the raspian build not expecting pi 4 normal operating temps, i doubt the pi4 is bad, any ideas here? thx
The Pi4 is known to get quite warm. Do you have heatsinks installed?
If you're looking for a cooler - here are two cases which act as cooler
Thanks for the responses but the pi4 is actively and passively cooled by the canakit case and it's at idle. Any other suggestions? I wonder if it's possible for OctoP show the tmp value when the alert triggered or provide an option to log/graph temps to better enable troubleshooting. It seems now the icon shows once it's triggered and never clears if normal operation is returned, but I'm not 100% sure in that?
Raspbian itself seems to be a little thick, if you ask me. Once a heat-throttled condition has existed, it's as if it stores this for the rest of its life (almost).
Info (It's as if those 16, 17 & 18 flags get stuck.) More
You might try...
sudo apt-get update
sudo apt-get upgrade
I, on the other hand, am very thankful for this nagging message. For weeks I kept ignoring it thinking that it must have been a false positive, as I power my Pi directly through GPIO pins from a 3A adjustable buck converter.
Well, it turned out that while the converter could successfully deliver the required 5.1V at 3A, the jumper cables I used to connect it all together were not up to the task and while I measured 5.1V at the converter and a little bit less at a "power hub" board (I'm using the same buck to power the RAMPS and Arduino Mega boards), the voltage between main power supply GND and +5V pin at the Pi was only 4.7V (and I'm guessing it was even lower between the on-Pi GND and +5V).
You may not notice anything except for the warning, but the Pi will be throttled. I definitely noticed some minor slowdowns e.g. at startup or in some more "dynamic" scenarios, but didn't connect the dots with the undervoltage throttling, rather suspecting microSD card wear or the like.
Today I replaced the jumper cables with manually crimped short 0.75mm² FLRY wires and the warning was gone (and I hope to never see it again).
To all who think this is not an issue, or think this is just a false positive, measure your voltage on board, try different cables (remember, not all USB cables can deliver 2.5A). You don't necessarily need to switch power supplies just yet. Check if the Pi is not throttling or if the throttling is really not affecting you.
It's good to hear this again. Some analysis follows...
  • 0.75 mm² = 18awg in case anyone was confused
Idea:
In theory you can also bring in 5V to BOARD pins 2 AND 4 and bring in two grounds to 34 & 39, for example (or any two convenient pins marked ground). In this way, you're doubling up the conductor.
Typical jumper cables for GPIO pins are (a tiny) 28awg = 0.08 mm², substantially less cross-section. The wire gauge requirement for 5V @ 3A over 6" with 14awg will drop it down to 4.95V by the time it hits the power bus which should be fine.
Convert the 14awg to cross section (2.5mm²), divide that by 2 (1.25mm²), look that up in the chart again and you're looking at two sets of 16awg (1.5mm²).
Either 14awg or 16awg seems huge compared to what we're typically using these days. Imagine trying to even jam the 16awg into a JST connector. Compare the cross-section of this to the JST connector itself or the GPIO pin. There are times when I think that the folks at the Raspberry Pi Foundation just aren't using their heads.
I am using the original Power supply I got with the Pi
So?
Can share a photo of the label on power supply?
I always label / mark my power supplies when I get them..
Can we please stop constantly questioning whether a reported undervoltage condition actually exists? If vcgencmd says the device is throttled, then the device is throttled. Period. That's nothing that can be negotiated with, it means the Pi detected that something is wrong and necessary mitigations were taken. No matter what your power supply says on its label, no matter what you have measured at one specific point in time, if vcgencmd reports an undervoltage event there was an undervoltage event. Which means either the power supply is insufficient, or the wiring from the power supply to the Pi is insufficient, or there's corrosion in the plug, or there's power fluctuations in your mains, or you have something connected to your Pi which drains enough power to cause undervoltage. In any case, something's wrong about the power and it needs to be fixed, there's no way around it.
