Throttled system
I want to install some updates on my OctoPi, but the system does not allow me to do so because 'the system is throttled'.
Error message:
'The system OctoPrint is running on is currently throttled. Due to that it's not possible to install new plugins in order to avoid possible issues caused by system instability.'
'OctoPrint is running on a throttled system, updates are disabled.
To reduce the likelihood of running into update problems on throttled and hence potentially unstable systems as seen in the past, OctoPrint doesn't support updating under such conditions. Please fix the current issue before trying to update. Take a look at the displayed warning in the navigation bar to learn about what is wrong and to get hints on how to solve the problem.'
I restarded my Raspberyy Pi and reconnected to Octopi.
Logs
octoprint_log.log (58.8 KB)
Additional information about your network
I am running Octoprint on a Raspberry Pi 3B module which is conencted through wifi. The Raspberry is connected to my Anet A8 printer by USB cable. I am able to connect to my printer and print stuff.
The system raspberry pi reports that it is not getting sufficient power (and/or is getting too hot). If this happens while writing things to the SD card, the file system may get corrupted. So it would be a bad idea to update things until the power issue is fixed.
Diagnose the power issue: what sort of power supply do you use? A phone charger is not a power supply. Cables (from the PSU to the Pi or even from the Pi to the printer) may also affect power issues. And finally, your printer may be "taking" too much current from your Pi, in which case a carefully placed piece of tape may help.
I recently experienced throttling on my rpi3+. Was using 2.5A 5V power adapter. I changed to another 2.5 A adapter and the throttling issue went away. - except throttling still occurred during startup of rpi. I then used the tape solution to stop the rpi from powering printer LCD when printer is off. I believe that stopped all throttling. So, 100% agree with fielOfView.
If both printer and Pi come up on the same power outlet (with switch) what you might try is to insert a boot_delay in Raspbian of two seconds to allow the printer board's power to become stable.
Hi There, Thanks for the reply, can you please provide either a photo or exact description of where/how to carefully places the tape
See Put tape on the 5V pin - Why and how
Hi, together! I had the problem today and found the solution quite easy.
I am using a 3A!! 5V plug power supply from my DJI Mavic Mini drone.
But at first I used an older relatively thin black USB Cable and got that warning message.
I then swapped the USB cable to the original DJI cable and the message was gone.
So maybe that could be an option form those who have a 2A + power supply.
Hello @WaldMaker
Are you sure it is a power supply and not a charger?
BTW: What Pi?
Well it's a 5V Plug Type power supply with an USB outlet .
The charge logic is in the battery case. But yes, the original purpose is to charge the three batteries.
My observation was mainly about the cable.
PI? PI 3 B+
...hence, it's a charger not an adapter.
Buy an official power adapter for the Pi.
I use official 3A Pi power supply with tape on 5V pin and Pi 3B + Pi Camera with IR sensors + Telegram plugin. But the system is undervoltage and throttled.
Even when no usb device is connected?
Yes. Only Ender-3 is connected by USB.
I mean without the ender connected :slight_smile:
If the pi only throttles when it is connected try this
I used my 3amp charger from my Mavic Mini Drone and the low voltage went away and the update was successful! Thank you all for contributing to a solution! You can never get an update to work if you have the low voltage warning lightning bolt on your pi screen or the voltage throttled line in your log!
Anyhow, a charger is always a bad decision. I may work now, but...
Chargers are built different than regular power supplies because they have to provide other needs of the device it connected to.
Thank you I bought a power supply with a switch. Is there a proper shutdown procedure or do I just click the switch off?
Please never do that. Eventually you will end with a corrupted file system on the SDcard.
You can shut down the Pi by this:
grafik
raspberries have plenty info on their health and well-being available if you ask nicely.
If you want to monitor the raspi's state and have an mqtt broker installed somewhere there is a python script (2.7) to collect those data and report it via mqtt.
Really useful when there are a few raspberries running, it helped me to identify power supply and temperature issues systematically and I generate nice graphs from it in connection with opeHAB/habpanel.
health.service
I faced this problem recently. In my case the Pi 3B+ is working fine when it's throttled. I made hundreds of 3D prints without any issues. But I couldn't update the OctoPrint. Then I realized that I can cheat the system that the Pi is not throttled.
  • Rename the original /usr/bin/vcgencmd
    sudo mv /usr/bin/vcgencmd /usr/bin/vcgencmd-dist
  • Create own script that always reports that the Pi is not throttled
    sudo touch /usr/bin/vcgencmd
    sudo chmod 755 /usr/bin/vcgencmd
    sudo nano /usr/bin/vcgencmd
  • Paste this text
    #!/bin/bash
    echo "throttled=0x0"
Now you can update the OctoPrint. If you want after the update you can restore the original script:
sudo rm /usr/bin/vcgencmd
sudo mv /usr/bin/vcgencmd-dist /usr/bin/vcgencmd
