🇺🇦 We stand with Ukraine! 🇺🇦
Updating OctoPi / not a directory
I want to update my OctoPi image to be uptodate.
Currently I have 0.14.0 and OctoPrint 1.3.10
I saw the blog entry about OctoPi 0.15.0 and 0.16.0, so I want to update my OctoPi.
When using the command: pip install --upgrade pip
I got error messages. So I used following commands to update pip (I thought so)
pi@octopi:~ $ sudo chown -R pi.pi ~/oprint ~/OctoPrint
pi@octopi:~ $ ~/oprint/bin/pip install https://get.octoprint.org/latest
Everything run through. but I am not able to navigate into the pip folder via: cd pip
Error message
pi@octopi:~/oprint/bin $ cd pip
-bash: cd: pip: Not a directory
Is it somehow possible to update OctoPi from 0.14.0 to 0.15.0 or higher?
What do I need to do to:
navigate to pip folder to check --version
Many thanks for your help
Best regards
Michael
There is no such thing as a pip folder. pip is a command, used to install python modules.
AFAIK, the only way to "upgrade" your OctoPi version is to start over. Use the new backup functionality in OctoPrint 1.3.10 to transfer your files and configuration
I downloaded the latest version of OctoPi/Octoprint from this side and after the installing process, I get this error message when updating to 1.3.12.
2019-11-04 12:09:30,978 ! Exception:
2019-11-04 12:09:30,979 ! Traceback (most recent call last):
2019-11-04 12:09:30,980 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
2019-11-04 12:09:30,981 ! status = self.run(options, args)
2019-11-04 12:09:30,982 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
2019-11-04 12:09:30,982 ! session=session, autobuilding=True
2019-11-04 12:09:30,983 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
2019-11-04 12:09:30,983 ! assert have_directory_for_build
2019-11-04 12:09:30,984 ! AssertionError
2019-11-04 12:09:32,401 ! You are using pip version 19.0.1, however version 19.3.1 is available.
2019-11-04 12:09:32,403 ! You should consider upgrading via the 'pip install --upgrade pip' command.
I've never seen a message like this but it looks like something is borked with that install. Based on the error it seems pip can't build a package it's trying to install due to having nowhere to write the result :face_with_raised_eyebrow:
File system full or corrupt?
I was so gonna include the Swedish Chef graphic there...
So, I did as follow:
  1. downloaded the zip:
  2. unziped
  3. formated the SD (16GB ScanDisk Ultra) using SDFormatter on Win10
  4. used balenaEtcher to flash the img to the SD card
  5. inserted the SD into a Rasp PI 3 B+
  6. went through the settings using PuTTY, PW for the pi user, local zone changed to Berlin
  7. went through the settings using the UI from OctoPrint
  8. got the update info to update to 1.3.12
  9. clicked on "Update"
got this error in the "Update" window/popup
Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages (from websocket-client<0.57,>=0.56->OctoPrint==1.3.12) (1.12.0)
Requirement already satisfied: pytz>=0a in /home/pi/oprint/lib/python2.7/site-packages (from Babel>=2.3->Flask-Babel<0.13,>=0.12->OctoPrint==1.3.12) (2018.9)
Exception:
AssertionError
Die Aktualisierung wurde nicht erfolgreich abgeschlossen. Bitte konsultiere octoprint.log und plugin_softwareupdate_console.log für Details.
plugin_softwareupdate_console.log (13.2 KB) octoprint.log (14.4 KB)
So, what should I try now?
I am sure I had this issue last time too, and fix it via consol, but theses skills has gone....
So, I found the corresponding ticket in the pip issue tracker:
What I do not understand is why I have never seen this before if it's a general issue with pip 19.0.1 as comes preinstalled with OctoPi 0.16. Maybe it is somehow related to the config changes you did... I'll have to try to reproduce it that way.
In any case, try the following via SSH:
source ~/oprint/bin/activate
pip install -U pip
That should install a newer version of pip which should have this particular bug fixed as far as I understand the aforementioned issue.
Exact same errors as Bigwerth when trying to update. Upgrading pip to version 19.3.1 fixed it, and the update went through.
Install process:
Etcher to write .img to SD Card
Notepad++ to change WiFi info
SSH via PuTTY
raspi-config to set password and time-zone (Mountain Time)
apt-get update && apt-get upgrade -y
reboot
Went to IP in browser and went through first time set-up
Clicked the notification for the update and started it
Hardware:
Raspberry Pi 3b+
SD Card: SanDisk 64GB Extreme ( SDSQXA2-064G-GN6MA)
I'm wondering if a dependency update happened since release of 1.3.12 that is now causing these kinds of issues in the field.
As far as I understand the pip issue it can be caused by any kind of package that's pulled in during an install, so that would make sense...
So I just tried this myself. Started with a fresh OctoPi 0.16 with OctoPrint 1.3.10. Updated to 1.3.12.
pip is 9.0.1. I don't get why some people are seeing this, but at least it doesn't appear to be a general issue for everyone now. I'll still add an FAQ entry for it.
OctoPi is unable to update OctoPrint from 1.3.10 to 1.3.12
  • Toggling plugin blacklist processing on startup
  • Using a Samsung microSHDC 32GB card
  • Using a Kingston microSHDC 8GB card
  • Restarting OctoPrint in safe mode
  • Re-downloading octopi-stretch-lite-0.16.0 image and re-etching with balenaEtcher
What hardware are you using?
Raspberry Pi 3B (a22082 1.2 1GB Embest)
Steps to reproduce
  1. Download octopi-stretch-lite-0.16.0 from OctoPrint.org - Download & Setup OctoPrint
  2. Extract and etch image to micro SD card using balenaEtcher
  3. Startup Raspberry Pi
  4. Browse to UI using Chrome
  5. Attempt to update
  6. Observe error
Error
Exception:
AssertionError
Logs
octoprint.log
2019-11-06 06:07:28,054 - octoprint.startup - INFO - ******************************************************************************
2019-11-06 06:07:28,057 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-11-06 06:07:28,057 - octoprint.startup - INFO - ******************************************************************************
2019-11-06 06:07:29,357 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-11-06 06:07:32,045 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-11-06 06:07:32,181 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-11-06 06:07:32,666 - octoprint.server - INFO - Intermediary server started
2019-11-06 06:07:32,668 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-11-06 06:07:33,266 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-11-06 06:07:33,268 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2019-11-06 06:07:33,414 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-11-06 06:07:33,416 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-11-06 06:07:41,795 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:43,364 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-11-06 06:07:43,366 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:07:43,367 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:07:43,372 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-11-06 06:07:43,875 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
|  Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Force Login (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin
|  Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-11-06 06:07:44,291 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 4
|    freq: 1200.0
|    ram: 918188032
|  os:
|    platform: linux2
|  plugins:
|    pi_support:
|      model: Raspberry Pi 3 Model B Rev 1.2
|      octopi_version: 0.16.0
|  python:
|    pip: 19.0.1
|    version: 2.7.13
|    virtualenv: /home/pi/oprint
2019-11-06 06:07:44,299 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-11-06 06:07:44,301 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-11-06 06:07:44,727 - octoprint.server - INFO - Shutting down intermediary server...
2019-11-06 06:07:45,023 - octoprint.server - INFO - Intermediary server shut down
2019-11-06 06:07:45,026 - octoprint.events - INFO - Processing startup event, this is our first event
2019-11-06 06:07:45,028 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-11-06 06:07:45,030 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-11-06 06:07:45,035 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-11-06 06:07:45,053 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-11-06 06:07:45,067 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-11-06 06:07:45,078 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-11-06 06:07:45,145 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-11-06 06:07:45,591 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020464909 (::ffff:192.168.1.23) 424.12ms
2019-11-06 06:07:46,374 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.77s
2019-11-06 06:07:46,648 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020466473 (::ffff:192.168.1.23) 9.74ms
2019-11-06 06:07:46,722 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2019-11-06 06:07:47,368 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:47,370 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:07:47,371 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:07:47,673 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020467529 (::ffff:192.168.1.23) 8.33ms
2019-11-06 06:07:47,781 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.1s
2019-11-06 06:07:48,602 - octoprint.server.views - INFO - Preemptive cache not active for path /, ui _default and data {'query_string': 'l10n=en', 'path': u'/', 'base_url': 'http://192.168.1.125/'}, signaling as cached
2019-11-06 06:07:48,782 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2019-11-06 06:07:49,377 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.78s
2019-11-06 06:07:50,198 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.74s
2019-11-06 06:07:50,331 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:51,061 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.74s
2019-11-06 06:07:53,861 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count': 1, '_timestamp': 1573020473.86114, 'base_url': 'http://192.168.1.125/'}
2019-11-06 06:08:01,836 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:08:01,837 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:08:01,881 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-11-06 06:08:01,947 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.125/'}
2019-11-06 06:08:16,718 - octoprint.server.preemptive_cache - INFO - ... done in 14.77s
2019-11-06 06:08:16,735 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020468551 (::ffff:192.168.1.23) 10.78ms
2019-11-06 06:08:18,507 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.23
2019-11-06 06:08:35,081 - octoprint.server.api - INFO - Actively logging in user octoprint from ::ffff:192.168.1.23
2019-11-06 06:08:37,739 - octoprint.server.util.sockjs - INFO - User octoprint logged in on the socket from client ::ffff:192.168.1.23
2019-11-06 06:09:23,762 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.12...
2019-11-06 06:11:00,316 - octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 969, in _perform_update
    update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
    raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
2019-11-06 06:09:23,773   /home/pi/oprint/bin/python2 -m pip install https://github.com/foosel/OctoPrint/archive/1.3.12.zip --no-cache-dir
2019-11-06 06:09:26,316 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-11-06 06:09:26,318 > Collecting https://github.com/foosel/OctoPrint/archive/1.3.12.zip
2019-11-06 06:09:26,821 ! DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
2019-11-06 06:09:27,324 > Downloading https://github.com/foosel/OctoPrint/archive/1.3.12.zip (5.4MB)
2019-11-06 06:09:33,569 > Requirement already satisfied: flask<0.11,>=0.10.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.10.1)
2019-11-06 06:09:33,570 > Requirement already satisfied: Jinja2<2.9,>=2.8.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2.8.1)
2019-11-06 06:09:33,571 > Requirement already satisfied: tornado==4.5.3 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (4.5.3)
2019-11-06 06:09:33,572 > Requirement already satisfied: Flask-Login<0.3,>=0.2.11 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.2.11)
2019-11-06 06:09:33,572 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2019.1.24)
2019-11-06 06:09:33,573 > Collecting Flask-Principal<0.5,>=0.4 (from OctoPrint==1.3.12)
2019-11-06 06:09:35,575 > Downloading https://files.pythonhosted.org/packages/14/c7/2531aca6ab7baa3774fde2dfc9c9dd6d5a42576a1013a93701bfdc402fdd/Flask-Principal-0.4.0.tar.gz
2019-11-06 06:09:37,579 > Collecting Flask-Babel<0.13,>=0.12 (from OctoPrint==1.3.12)
2019-11-06 06:09:38,696 > Downloading https://files.pythonhosted.org/packages/82/b0/986b29938d4e8be7deb552ebfd1ef16c311276a59bcae10dec567a5b3d20/Flask-Babel-0.12.2.tar.gz (44kB)
2019-11-06 06:09:40,730 > Collecting Flask-Assets<0.13,>=0.12 (from OctoPrint==1.3.12)
2019-11-06 06:09:41,897 > Downloading https://files.pythonhosted.org/packages/86/ff/6000451570745d7a90847f6528d96d6b24c800eaaf9f26cf398accd8cee5/Flask-Assets-0.12.tar.gz
2019-11-06 06:09:43,900 > Collecting werkzeug<0.16,>=0.15.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:45,946 > Downloading https://files.pythonhosted.org/packages/b7/61/c0a1adf9ad80db012ed7191af98fa05faa95fa09eceb71bb6fa8b66e6a43/Werkzeug-0.15.6-py2.py3-none-any.whl (328kB)
2019-11-06 06:09:46,825 > Collecting cachelib<0.2,>=0.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:46,826 > Downloading https://files.pythonhosted.org/packages/e6/5b/39d1f9071e95123a4ae6d8bdeb53416d1af601f662641eac9b0d7c844dba/cachelib-0.1.tar.gz
2019-11-06 06:09:49,093 > Collecting PyYAML<6,>=5.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:50,595 > Downloading https://files.pythonhosted.org/packages/e3/e8/b3212641ee2718d556df0f23f78de8303f068fe29cdaa7a91018849582fe/PyYAML-5.1.2.tar.gz (265kB)
2019-11-06 06:09:53,914 > Collecting markdown<3.1,>=3.0 (from OctoPrint==1.3.12)
2019-11-06 06:09:55,724 > Downloading https://files.pythonhosted.org/packages/7a/6b/5600647404ba15545ec37d2f7f58844d690baf2f81f3a60b862e48f29287/Markdown-3.0.1-py2.py3-none-any.whl (89kB)
2019-11-06 06:09:56,498 > Requirement already satisfied: pyserial<3.5,>=3.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (3.4)
2019-11-06 06:09:56,499 > Requirement already satisfied: netaddr<0.8,>=0.7.19 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.7.19)
2019-11-06 06:09:56,499 > Collecting watchdog<0.10,>=0.9.0 (from OctoPrint==1.3.12)
2019-11-06 06:09:56,500 > Downloading https://files.pythonhosted.org/packages/bb/e3/5a55d48a29300160779f0a0d2776d17c1b762a2039b36de528b093b87d5b/watchdog-0.9.0.tar.gz (85kB)
2019-11-06 06:09:58,263 > Requirement already satisfied: sarge==0.1.5post0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.1.5.post0)
2019-11-06 06:09:58,264 > Requirement already satisfied: netifaces<0.11,>=0.10.9 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.10.9)
2019-11-06 06:09:58,265 > Collecting pylru<1.3,>=1.2 (from OctoPrint==1.3.12)
2019-11-06 06:09:59,583 > Downloading https://files.pythonhosted.org/packages/9c/88/30972cd0518452563221c80bffc2a5832499d736648ef8fe492affae15c5/pylru-1.2.0.tar.gz
2019-11-06 06:10:03,588 > Collecting rsa<5,>=4.0 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,875 > Downloading https://files.pythonhosted.org/packages/02/e5/38518af393f7c214357079ce67a317307936896e961e35450b70fad2a9cf/rsa-4.0-py2.py3-none-any.whl
2019-11-06 06:10:05,876 > Collecting pkginfo<1.6,>=1.5.0.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,876 > Downloading https://files.pythonhosted.org/packages/e6/d5/451b913307b478c49eb29084916639dc53a88489b993530fed0a66bab8b9/pkginfo-1.5.0.1-py2.py3-none-any.whl
2019-11-06 06:10:05,877 > Requirement already satisfied: requests<3,>=2.21.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2.21.0)
2019-11-06 06:10:05,878 > Collecting semantic_version<2.7,>=2.6 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,878 > Downloading https://files.pythonhosted.org/packages/72/83/f76958017f3094b072d8e3a72d25c3ed65f754cc607fdb6a7b33d84ab1d5/semantic_version-2.6.0.tar.gz
2019-11-06 06:10:07,881 > Collecting psutil<5.7,>=5.6.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:11,885 > Downloading https://files.pythonhosted.org/packages/47/ea/d3b6d6fd0b4a6c12984df652525f394e68c8678d2b05075219144eb3a1cf/psutil-5.6.4.tar.gz (447kB)
2019-11-06 06:10:11,886 > Installing build dependencies: started
2019-11-06 06:10:23,895 > Installing build dependencies: finished with status 'done'
2019-11-06 06:10:23,896 > Getting requirements to build wheel: started
2019-11-06 06:10:31,903 > Getting requirements to build wheel: finished with status 'done'
2019-11-06 06:10:31,904 > Preparing wheel metadata: started
2019-11-06 06:10:33,908 > Preparing wheel metadata: finished with status 'done'
2019-11-06 06:10:33,909 > Collecting Click<8,>=7 (from OctoPrint==1.3.12)
2019-11-06 06:10:35,322 > Downloading https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl (81kB)
2019-11-06 06:10:35,323 > Requirement already satisfied: awesome-slugify<1.7,>=1.6.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (1.6.5)
2019-11-06 06:10:35,324 > Requirement already satisfied: feedparser<5.3,>=5.2.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (5.2.1)
2019-11-06 06:10:35,324 > Collecting chainmap<1.1,>=1.0.3 (from OctoPrint==1.3.12)
2019-11-06 06:10:35,325 > Downloading https://files.pythonhosted.org/packages/c7/ab/268a15383b75ca3e58ce344bce165b79768e516f8e79c87cbdaba30c38e9/chainmap-1.0.3.tar.gz
2019-11-06 06:10:37,328 > Collecting future<0.18,>=0.17.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:38,645 > Downloading https://files.pythonhosted.org/packages/90/52/e20466b85000a181e1e144fd8305caf2cf475e2f9674e797b222f8105f5f/future-0.17.1.tar.gz (829kB)
2019-11-06 06:10:41,763 > Collecting scandir<1.11,>=1.10 (from OctoPrint==1.3.12)
2019-11-06 06:10:43,766 > Downloading https://files.pythonhosted.org/packages/df/f5/9c052db7bd54d0cbf1bc0bb6554362bba1012d03e5888950a4f5c5dadc4e/scandir-1.10.0.tar.gz
2019-11-06 06:10:45,770 > Collecting websocket-client<0.57,>=0.56 (from OctoPrint==1.3.12)
2019-11-06 06:10:47,101 > Downloading https://files.pythonhosted.org/packages/29/19/44753eab1fdb50770ac69605527e8859468f3c0fd7dc5a76dd9c4dbd7906/websocket_client-0.56.0-py2.py3-none-any.whl (200kB)
2019-11-06 06:10:47,102 > Collecting wrapt<1.12,>=1.11.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:48,104 > Downloading https://files.pythonhosted.org/packages/23/84/323c2415280bc4fc880ac5050dddfb3c8062c2552b34c2e512eb4aa68f79/wrapt-1.11.2.tar.gz
2019-11-06 06:10:50,108 > Collecting futures<3.3,>=3.2 (from OctoPrint==1.3.12)
2019-11-06 06:10:51,426 > Downloading https://files.pythonhosted.org/packages/2d/99/b2c4e9d5a30f6471e410a146232b4118e697fa3ffc06d6a65efde84debd0/futures-3.2.0-py2-none-any.whl
2019-11-06 06:10:51,427 > Collecting emoji<0.6,>=0.5.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:51,428 > Downloading https://files.pythonhosted.org/packages/40/8d/521be7f0091fe0f2ae690cc044faf43e3445e0ff33c574eae752dd7e39fa/emoji-0.5.4.tar.gz (43kB)
2019-11-06 06:10:53,545 > Collecting monotonic<1.6,>=1.5 (from OctoPrint==1.3.12)
2019-11-06 06:10:54,925 > Downloading https://files.pythonhosted.org/packages/ac/aa/063eca6a416f397bd99552c534c6d11d57f58f2e94c14780f3bbf818c4cf/monotonic-1.5-py2.py3-none-any.whl
2019-11-06 06:10:54,926 > Requirement already satisfied: frozendict<1.3,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (1.2)
2019-11-06 06:10:54,926 > Collecting sentry-sdk==0.7.7 (from OctoPrint==1.3.12)
2019-11-06 06:10:56,293 > Downloading https://files.pythonhosted.org/packages/cb/61/709cf211413ed28c0606fe135cd41b7d94ffdc49d874aeba37b6e0d20000/sentry_sdk-0.7.7-py2.py3-none-any.whl (60kB)
2019-11-06 06:10:56,602 > Collecting typing<4,>=3.6.6 (from OctoPrint==1.3.12)
2019-11-06 06:10:58,294 > Downloading https://files.pythonhosted.org/packages/22/30/64ca29543375759dc589ade14a6cd36382abf2bec17d67de8481bc9814d7/typing-3.7.4.1-py2-none-any.whl
2019-11-06 06:10:58,295 > Collecting filetype<2,>=1.0.5 (from OctoPrint==1.3.12)
2019-11-06 06:10:58,296 > Downloading https://files.pythonhosted.org/packages/1c/78/047cf0f371f8faafab05b5062f902d4bedd945d436544b30db692622ab84/filetype-1.0.5-py2.py3-none-any.whl
2019-11-06 06:10:58,297 > Requirement already satisfied: itsdangerous>=0.21 in /home/pi/oprint/lib/python2.7/site-packages (from flask<0.11,>=0.10.1->OctoPrint==1.3.12) (1.1.0)
2019-11-06 06:10:58,297 > Requirement already satisfied: MarkupSafe in /home/pi/oprint/lib/python2.7/site-packages (from Jinja2<2.9,>=2.8.1->OctoPrint==1.3.12) (1.1.0)
2019-11-06 06:10:58,298 > Requirement already satisfied: singledispatch in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (3.4.0.3)
2019-11-06 06:10:58,298 > Requirement already satisfied: certifi in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (2018.11.29)
2019-11-06 06:10:58,298 > Requirement already satisfied: backports-abc>=0.4 in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (0.5)
2019-11-06 06:10:58,299 > Requirement already satisfied: blinker in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Principal<0.5,>=0.4->OctoPrint==1.3.12) (1.4)
2019-11-06 06:10:58,299 > Requirement already satisfied: Babel>=2.3 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<0.13,>=0.12->OctoPrint==1.3.12) (2.6.0)
2019-11-06 06:10:58,300 > Requirement already satisfied: webassets>=0.11.1 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Assets<0.13,>=0.12->OctoPrint==1.3.12) (0.12.1)
2019-11-06 06:10:58,300 > Requirement already satisfied: argh>=0.24.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<0.10,>=0.9.0->OctoPrint==1.3.12) (0.26.2)
2019-11-06 06:10:58,301 > Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<0.10,>=0.9.0->OctoPrint==1.3.12) (0.1.2)
2019-11-06 06:10:58,301 > Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python2.7/site-packages (from rsa<5,>=4.0->OctoPrint==1.3.12) (0.4.5)
2019-11-06 06:10:58,302 > Requirement already satisfied: urllib3<1.25,>=1.21.1 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (1.24.1)
2019-11-06 06:10:58,302 > Requirement already satisfied: idna<2.9,>=2.5 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (2.8)
2019-11-06 06:10:58,303 > Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (3.0.4)
2019-11-06 06:10:58,303 > Requirement already satisfied: Unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python2.7/site-packages (from awesome-slugify<1.7,>=1.6.5->OctoPrint==1.3.12) (0.4.21)
2019-11-06 06:10:58,304 > Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages (from websocket-client<0.57,>=0.56->OctoPrint==1.3.12) (1.12.0)
2019-11-06 06:10:58,304 > Requirement already satisfied: pytz>=0a in /home/pi/oprint/lib/python2.7/site-packages (from Babel>=2.3->Flask-Babel<0.13,>=0.12->OctoPrint==1.3.12) (2018.9)
2019-11-06 06:10:58,806 ! Exception:
2019-11-06 06:10:58,807 ! Traceback (most recent call last):
2019-11-06 06:10:58,808 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
2019-11-06 06:10:58,809 ! status = self.run(options, args)
2019-11-06 06:10:58,809 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
2019-11-06 06:10:58,810 ! session=session, autobuilding=True
2019-11-06 06:10:58,810 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
2019-11-06 06:10:58,811 ! assert have_directory_for_build
2019-11-06 06:10:58,811 ! AssertionError
2019-11-06 06:11:00,314 ! You are using pip version 19.0.1, however version 19.3.1 is available.
2019-11-06 06:11:00,314 ! You should consider upgrading via the 'pip install --upgrade pip' command.
I had the same issue, Was able to fix it by upgrading "PIP"
sudo apt-get update
pip install -U pip
Also see Updating OctoPi / not a directory
FAQ entry is now up:
This worked to resolve the issue I was experiencing.
