Trying to get Raspberry pi Camera to work
#1
I get the following log:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Feb 24 08:42:49 pi: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: (null)
libv4l2: error turning on stream: Invalid argument
Unable to start capture: Invalid argument
i: Error grabbing frames
I updated to the latest pi update using the commandline. Also tested:
$ vcgencmd get_camera
supported=1 detected=1
I used raspi-config to enable the camera.
#2
Hi @WauloK
A quick forum search gave these:
https://community.octoprint.org/search?q=pi%20cam
#3
The red light on the camera is on. None of those links have an answer so I'll search I guess.
